Tsudo/MMW Header Install
Tsudo or MMW header...
Are you putting the header in through the top or the bottom?
It wasn't going in when putting it from the top, and it got a lot further when put in from the bottom.
I need a quick answer. Face palm.
not really horrible fitment, jus tedious to install, and its only the MMW & Tsudo that are like that. but besides that compared to most cars like my old MK3 jetta the tc header install is cake.
Where the header meets the block, I had to pound it on with a hammer. Did not line up.
S Pipe to mid... didn't line up right. I've install many exhausts before. I think I just got unlucky.
take out dipstick and fan shroud and put in from the bottom,carefull of the radiator,it has a tight fit to get past,if you have an automatic it is even worse to get past the coolant lines.
take off the fan, and it'll open up a lot of space for you. when i installed mine, i did it from the top. when i uninstalled it, i just let it down through the engine bay, meaning both ways can be done. just wiggle it in and enjoy the rasp.
