TWM Stage 2 Qustion... INFO NEEDED!!!
Old Nov 29, 2009 | 06:30 PM
AdmirN's Avatar
Default TWM Stage 2 Qustion... INFO NEEDED!!!
So im about to order the TWM 2 and im 100% sure im going to get the cage raisers from Doc I. The Q is, should i order both the Base and Cage bushing from TWM or should i just order the Cable bushing along with the raisers and not even get the Base bushing from TWM???
I just want my shifting to feel smooth and soft(not so stiff) if that kinda helps...
Old Nov 29, 2009 | 08:50 PM
Joyride's Avatar
Doesnt matter you can mix and match companies nothing will happen. same ____ in the end.
Old Nov 29, 2009 | 10:32 PM
AdmirN's Avatar
I know i can mix and match i was just wondering which one should i go with....
Old Nov 30, 2009 | 12:03 AM
ScionSnowman's Avatar
Doc I, just because he's a great guy with a great product. Money is better put into the hand of a small business vs a huge company.
Old Nov 30, 2009 | 12:08 AM
engifineer's Avatar
You should just buy the shifter from Doc as well ;)
Old Nov 30, 2009 | 02:22 AM
gwtc's Avatar
Doc's stuff is the best, my TWM shifter took a dump on me, I will never buy anything from them ever again, get everything from DOC I, you will not regret it.
Old Nov 30, 2009 | 02:54 AM
bigBOAT's Avatar
how does a shifter take a dump
Old Nov 30, 2009 | 10:50 AM
Engifineer is right, post that shifter in classified and pick up Doc I's product!
Old Nov 30, 2009 | 03:28 PM
engifineer's Avatar
There have been some (I think CC was one.. TWM may have had the issue too. not sure) that were manufactured with the pivot ball a bit too small. This allowed too much slop in the assembly.
Doc makes his from stock shifters by moving the pivot ball to shorten the throw and cutting the shifter down if needed to reduce height. So proper fitment of the pivot is a given.
Old Nov 30, 2009 | 08:09 PM
gwtc's Avatar
lol....I should have been more specific, like engifineer said, the pivot ball was made too small, so the shifter stick eventually started to loosen and would turn inside the ball, it was very uncomfortable shifting sometimes when the shifter was in the wrong position, hope that makes sense, he he...
Old Dec 1, 2009 | 01:41 AM
engifineer's Avatar
Trying to wiggle it with the ball in the wrong position can be very uncomfortable.....
Old Dec 1, 2009 | 12:01 PM
bigBOAT's Avatar
haha makes scence now i have not had one issue with my twm very interesting tho
Old Dec 1, 2009 | 04:49 PM
gwtc's Avatar
My problem started when I was tightening my shift ****, I guess I turn it too hard and that's when it started coming loose.
disaster06
Feb 3, 2015 08:50 PM
Xaphoon
Jan 17, 2015 02:12 AM
disaster06
Dec 26, 2014 03:00 PM
rancur3p1c
Dec 19, 2014 04:30 PM
XB_2
Nov 23, 2014 02:48 PM
