hey, getting a turbo kit soon, and was just wondering if i run a risk exploding the engine......i realize the more psi the more possibilty of trouble, but i got a deal, and was wondering if i run the kit at like 5 psi or lower as a daily driver, will i dmamage anything?? id get a clutch along with the kit and stuff also................let me know, if i put a turbo on , nomatter what does that make it a risk?...................let me know..................thanks all :pray: .......
hotbox05
02-09-2005, 03:07 AM
5psi if fueled correctly will run for a long time with virtually no problems . just make sure you use a turbo timer.
DarkBoxJr
02-09-2005, 08:22 AM
Turbo timers are a waste of money. He's going to have other things to worry about if he decides to turbocharge without knowing everything that needs to be done.
hotbox05
02-09-2005, 08:59 AM
well i think turbo timers are very worth it unless u like sitting around with yer car on for a few minutes after driving , or if u like to burn oil and kill a motor. the second part of your post is true tho. it's ok we can all learn.
one of the main reasons factory turbo cars don't last as long as they should is the absence of a turbo timer cuz most peeps wont sit around letting the car idle for a few minutes after driving and will run the car hard just to immediately shut er down thus burning oil and ruining seals.
KingLou
02-09-2005, 05:41 PM
The remote start alarm I got from Bill (scionspecialistvegas) can be programmed for a turbo timer function. It leaves the car running for a few mins after you kill the ignition.
KiL
Matixten
02-09-2005, 05:56 PM
Well to be honest with you, I think you won't do much harm to the xB. Buttt........... I know when people get a turbo they tend get on it from the get-go. Break everything in, and then get buck wilded. Thats what I think.
02-09-2005, 06:10 PM
Why get turbo if you're only going to run 5psi? It's a bit of a waste imo..
Go with the supercharger if you're only going for a daily driver, you'll get much better response in low to midrange torque, and have better reliability in the long run.
fusionscion
02-09-2005, 06:48 PM
Go with the supercharger if you're only going for a daily driver, you'll get much better response in low to midrange torque, and have better reliability in the long run. there isnt a need to have a scion go all out at all times, when just crusing down the street..... id keep at 5psi for reliablility with a turbo, and turn it up whenever i want a bigger smile........lol this is the tsi turbo kit, any body heard of it be4? let me know
TheScionicMan
02-09-2005, 07:11 PM
I would read this page and think about the risks you're willing to assume:
http://elprototypes.com/1nz%20turbo.htm
This is what these guys do and the experience they have had with our engine.
It responds to boost quite nicely with a properly sized turbo. But its downfalls are the internals and its engine management.
Lets touch on the internals. First and foremost are the rods. Although quite strong for their size, they are designed for normal aspiration only. A half point higher in compression is about all they can handle daily without failure. Once boost is added to the equation, it becomes Russian roulette as to when they will let loose. You may last eight months with 50,000 miles or blow it the first pass down the street; there are no warning signs.
These engines have the crankshaft offset 12mm to the thrust side of the cylinder bore centerline. This reduces the side force generated at maximum compression, for reduced friction and improved fuel economy. Toyota calculates the offset crankshaft configuration reduces fuel consumption by between one and three percent. Unfortunately, this throws the angle of the rod way out on its upward travel causing the rod to just give up under boost and snap. If there is any detonation or pre-ignition this breakage will occur at an accelerated rate.
EMU
02-10-2005, 12:56 AM
good luck on fuel management...heard its a biatch
unlmtdndeavor
02-10-2005, 12:58 AM
erics the man when it comes to toyotas. and i believe him when he says these engines wont hold the power for long.
jdaniels
02-10-2005, 02:06 AM
Sorry to ____ in your fire, but the kit isn't for the xB. I own the kit, it's absolute trash. I rebuilt the whole damn thing myself, replacing every part but the intercooler and the charge pipes. Nothing fit without serious mods. The fuel system is useless.
You are much better off getting the GReddy JDM kit -- this kit is NOT reliable at all... and their customer service is horrible. But, I suggest talking to EL Prototypes honestly.
You never read about this kit in my posts?!? I've wrote things up before about this kit, its GARBAGE! The turbo seals went bad in 2 weeks, and the turbo is IN warranty but TSI avoids me... I've had it since August, when they still said it was for the xB.
Anyhow, LISTEN to me. DON'T BUY IT. :nope:
fusionscion
02-10-2005, 06:45 PM
Anyhow, LISTEN to me. DON'T BUY IT. :nope: damn i am now thinking about the paxton supercharger kit, i havent been able to find one for a good price yet...........
hotbox05
02-10-2005, 07:07 PM
Paxton kit? You mean the power enterprises centrifugal?
fusionscion
02-10-2005, 07:16 PM
Paxton kit? You mean the power enterprises centrifugal? dammit i knew i said the wrong one, damn im stupoid but w/e... anybody nkow of where i can get a kit like this for a great price?
DibujoB
02-10-2005, 07:19 PM
we were running our supercharged xB at 5psi with no problems.
