what spring to get in BOV?
Old Dec 3, 2009 | 05:25 PM
highvoltage1's Avatar
Default what spring to get in BOV?
Ima be getting a Tial Q BOV. I dont know how to determine what spring to get in the BOV. I can go as low as 6psi spring. I was told to get a 10psi spring but I plan on running max 10-12psi of boost but will initially be running around 8 psi. Not sure if that is what is used to determine spring usage. Remember I am talking about BOV not wastegate! I know how to determine wastegate spring.
Thanks.
Old Dec 3, 2009 | 05:29 PM
ElevationTC's Avatar
bud, it told you the 12psi spring for the BOV
Old Dec 3, 2009 | 05:36 PM
Oh ok. Well i know your running alot more psi than me. So i just wanna get a few more opinions. Thats all bro. I mean does boost psi not matter for the BOV? what does the spring psi mean on the BOV?
Old Dec 3, 2009 | 05:37 PM
its for vaccum
Old Dec 3, 2009 | 05:42 PM
Oh ok. But will our vaccum differ or will turbo tc's vacuum be similiar?
Old Dec 3, 2009 | 05:48 PM
bdis3's Avatar
On Tial's website there is a chart to tell you what spring to use. It depends how much vacuum you pull at idle.
tialsport.com
Old Dec 3, 2009 | 05:49 PM
SoFloTC's Avatar
tc's generally pull the same vacuum on boost.. like 19-22 is generally what ive seen
so on their site it says the 11psi spring
Old Dec 3, 2009 | 06:01 PM
Ok. Yea i have no clue what vacuum we pulled so thats why i asked. I appreciate the hlep fellas!
Old Dec 5, 2009 | 08:06 PM
jwaggz82's Avatar
If you really want to make sure - use a smaller spring and find out if it holds the boost and doesnt leak, the move to the stiffer spring. I would say that a 12lb spring is prob what you need though. You just dont want it leaking - do you have a boost gauge you can test w/?
Old Dec 5, 2009 | 08:12 PM
wow, you guys are making this so much harder then it needs to be LOL!
Old Dec 5, 2009 | 08:48 PM
Im just gna get a 12lb spring
Old Dec 5, 2009 | 08:57 PM
Mike im guessing the Tial BOV with your P-tuning kit came with the 12psi spring?
Old Dec 5, 2009 | 09:00 PM
Oh and what size vac hose should i buy?
Old Dec 5, 2009 | 09:02 PM
In both tials i had i ran the 12 psi bov spring! worked flawless!
tckid21
Jan 9, 2016 09:19 PM
brett561tc
Sep 15, 2015 06:33 AM
Mjdavis1994
Jul 18, 2015 04:29 AM
goatbelly
Jul 12, 2015 10:13 AM
Naughtygoose
Jul 6, 2015 09:59 PM
