Coolant Lines?
Old Dec 6, 2009 | 06:41 PM
car_ram_rod's Avatar
Default Coolant Lines?
I have a turbonetics kit and recently discovered it's a water cooled turbo. From what I've read is people are using their throttle body return line. I would imagine we need to use high temp braided line. What types of lines/fittings are people using and where are they getting them?
Old Dec 6, 2009 | 06:43 PM
Blue_TC_Man's Avatar
did the kit not come with lines for the water cooling??
but yeah just bypass the throttle body and run those lines to the turbo, it should have fittings on the turbo. IDK if they would be AN for a braided line, or just brabed so you can runner heater line to it
Old Dec 6, 2009 | 06:54 PM
Correct there are no water cooling lines. The turbo has 2 threaded inlet and outlet ports. I believe I need to use banjo style fittings, and I'm wondering if SS is a necessity and what adapters, lines, etc people are using. Do you believe I could use banjo fittings with barbed ends and standard heater hose?
Old Dec 6, 2009 | 07:08 PM
Ace83's Avatar
Ronin Scion
if you got it new, you should contact the vendor or turbonetics.. you can use regular coolant lines but SS would be nice... most use -6 an fittings for water cooled turbo not sure bout turbonetics
Old Dec 6, 2009 | 08:41 PM
I got it in the For Sale section and I didn't know it was water cooled. I just emailed turbonetics maybe they can be of some help.
Old Dec 6, 2009 | 08:46 PM
its probably -6 an, if not and it is a banjo fitting thats needed, a barbed banjo fitting and some heater hose or silicone hose will work fine
Old Dec 6, 2009 | 09:09 PM
Thanks Blue I'll see if I can't find a barbed banjo fitting that will work at a local store.
Old Apr 15, 2010 | 12:10 PM
maherdan82's Avatar
Turbonetics sell a complete braided kit for the tc. It connects to the heater hoses and sells for 100 bucks. A bit pricey but really nice.
gqdabien
Oct 8, 2015 05:36 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
edwinisdumb15
Regional - Pacific South
Sep 18, 2015 10:48 PM
prescottn
Sep 13, 2015 09:04 PM
gottoaster
Sep 6, 2015 07:17 PM
