MAF sensor issues w/ CAI
Old Dec 6, 2009 | 07:53 PM
LuckyPablo7's Avatar
Default MAF sensor issues w/ CAI
I got the Tenzo CAI and ive been getting the CEL Ive tried every single "fix" I could find in the web and no success grrrrrr Only thing i havent done is switching it to a Short Intake; before i do I was wondering if there is a way to check if the actual MAF sensor is bad? Or if i just ride w/ the CEL on due to that will the car perform badly????
Thanks
Old Dec 6, 2009 | 07:56 PM
ack154's Avatar
Have you checked to see what code you're actually getting?
Old Dec 6, 2009 | 08:04 PM
KendoStick1's Avatar
did u disconnect the battery for 5 mins? checked the actual maf sensor itself to see if there's any debris on there?
Old Dec 6, 2009 | 08:24 PM
pno02's Avatar
i had the same problem with an ebay cai. cleaned the sensor and everything, tried making it a short ram and it didnt help. saving up for a fujita now
Old Dec 6, 2009 | 08:45 PM
Blue_TC_Man's Avatar
either your maf is dirty or bad. Reset the ecu, but just putting a pipe on your throttle body wont mess anything up
Old Dec 6, 2009 | 09:46 PM
pno02's Avatar
i was told that with the diameter of the pipe being slightly larger where the maf goes is what causes the cel. i noticed on the fujita that the pipe steps down in size where the sensor is located. it doesnt make sense to me why the diameter makes the light come on because you can only flow so much air into the motor so idk what makes the sensor think something is wrong
Old Dec 6, 2009 | 10:15 PM
NaughTC's Avatar
wat model is ur car? wat year is ur car? ur car and cai must have same year. 05-06 tc have smaller hole for the sensor. 07+ have larger holes.
Old Dec 6, 2009 | 10:24 PM
Tc4Eva's Avatar
Team ScionTific
Make sure the sensor isnt dirty, or installed backwards.
Old Dec 6, 2009 | 10:29 PM
Sorry shouldve provided more info i have 07 tc; yes i reset ECU thats the only thing that clears the CEL; sometimes it will go off till i hit 80miles or once i hit 250 mile or recently its just after 25miles;
I bought MAF sensor cleaner did that No success!!! I will try to clean it again tomorrow but ive read that most ppl had better luck switching it to short.
Let's say I decided to leave it CAI and i keep riding with the CEL and it's the MAF code; will this reduce the performance of the car?? Im thinking yes, (but iam a noob so just asking) seems logical that the ecu could send a mssg to protect engine
Tomorrow ill pass by autozone and get the code as well
Any other suggestions? Thanks for all of the help!!!!!
Also, how can I know if the actual MAF sensor is bad??? (will suck if it is grrr)
Old Dec 6, 2009 | 10:36 PM
a code will help, but if the MAF doesnt fill the entire pipe and unmetered air is getting by it, it will cause a code. But thats the only reason I could think of.
Old Dec 6, 2009 | 10:53 PM
Yeah ive seen a couple of ppl that decided to use some silicone to cover the base of it to make sure no air is sneaking in....may do that tomorrow as well......
Old Dec 7, 2009 | 12:09 AM
cburglb34's Avatar
ughhh some people just dont ever get it........the 07-08 scion tc have a 2.5 inner diameter pip from factory if u use anything larger u WILL GET A CEL!!! reason being is the larger the diameter the less air is being metered, the smaller the pipe the more air is being metered, if u were turbo or did any tuning urself you would know this cuz you have to adjust maf readings according to your pipe size
Old Dec 7, 2009 | 12:20 AM
Yes I think we are all aware of that, and the tenzo intake becomes thinner in the section that the MAF sensor is hooked up on. So im thinking it cant be the issue since ive seen tc owners with this intake and no CEL. So im pretty sure it cant be that......... But you hit a point; how can you adjust the maf readings?? stand alone???
Old Dec 7, 2009 | 12:46 AM
cburglb34's Avatar
no any piggyback can adjust maf readings, AEM FIC is the best bang for you buck all around
try the silicone and if that doesnt fix then u might have damaged ur maf while installing it
Old Dec 7, 2009 | 12:47 AM
cburglb34's Avatar
good thing is u can buy used mafs on ebay for cheap i got mine for under 40, i search up the maf for a sienna which also happens to be the one for the07-09 tc
Old Dec 7, 2009 | 02:38 AM
cmcpride's Avatar
lol. over and over again but your not giving us codes...... # there is no such thing as maf code.. only related codes that suggest maf problem. what code are you getting.
p---
Old Dec 7, 2009 | 02:44 AM
cmcpride's Avatar
you may also have evap codes p0456, p0455, p0440.. or even a/f sensor codes. i know toyota upgraded a/f sensor regarding incorrect reading lean conditions.
Old Dec 7, 2009 | 08:05 PM
chekmi21's Avatar
I have the FUJITA and I'm getting the CEL as well. Car was bought used with the FUJITA in there and it set off the CEL. Took it back to the dealer and they put a new MAF. It still went off. They said I need to change back to stock.
Old Dec 7, 2009 | 08:21 PM
there liars, get the code checked
Old Dec 9, 2009 | 02:00 AM
Quick Update!!
Ok got up and decided to re clean the MAF sensor, used silicone at the base to make sure no air is getting thru!!! AS of right know no CEL but ive only ridden about 15miles. Hopefully it wont come up again but if it does ill post the codes for it (sorry i didnt get the codes before the clean up i did)
Thanks for the help everyone will keep you posted <crossing fingers>
