LucidBD
02-10-2005, 04:16 AM
ok so i need to know if these will fit on tC with 1"- 1.5" drop....anyone? this setup is Staggered.
19"X8.5", 37 offset, 19"X9.5", 37 offset, 5X112 bolt pattern.
VIP_tC
02-10-2005, 04:01 PM
should fit ok except wrong bolt pattern - you need 5X100... Although I havent seen that exact offset, although I know a 35 front and 40 rear work in those sizes.
RogerTTR
02-10-2005, 07:43 PM
FYI, our fitment team recommends 19X8, 5-100, ET45. An offset of 37mm may be a little aggressive, as well as the 9.5" rear. Also, as pointed out, you are going to need a 5-100 bolt pattern!
JDMJim
02-10-2005, 09:18 PM
I squeezed a +30 front and rear on to my wifes tC. THe wheels weren't mine, they were just a check.
LucidBD
02-11-2005, 02:28 AM
ok so 19"x8", 35 offset, 19"x8", 35 offset 5X100 should be ok with the 1-1.5" drop?
r0cky1nyc
08-23-2006, 05:56 AM
would you be able to put 19x8.5 on the front
and 19x9.5 on the back
and if so what size tires would you go with
Chapman
08-23-2006, 09:44 AM
That's fine. I have the same setup and I rub a lil bit only (need to shave more fender). I have no wheel gap front and back so that's why I'm rubbing. Also running stretched 215/35/19 falkens.
nodnarb
08-24-2006, 07:00 PM
I have 19x8.5 with a 45 offset and tire size are 225/35 and no rubbing whatsoever
