Amp the Stock Speakers?
Old Feb 10, 2005 | 04:17 AM
ugly_duck's Avatar
Default Amp the Stock Speakers?
Has anyone put an amp to the stock speakers? Is it worth it and is volume increased? I plan on running an aftermarket hu so im sure it will sound better.
Anyone know the Model and specs to the stock speakers?
Thanks all
-Ryan
Old Feb 10, 2005 | 04:33 AM
Twidget722's Avatar
The power handling of pretty much all stock speakers is far too low to handle a amp, you are better off not spending the money on the amp and just upgrading the speakers (and head unit as planned) then later on down the road do a amp to the speakers. Also what are you looking for lots of bass or a clean balenced sound?
John
Old Feb 10, 2005 | 09:23 AM
hou8389's Avatar
i used a memphis 75x4 amp on my stock speakers and they sound alot better. i crank it up all the way and have not blone one yet and it has been almost ten mounths since i did that. the speakers can take it.
Old Feb 10, 2005 | 09:39 AM
DunDeal's Avatar
our stock speakers are pioneer so if u put an amp it should sound good. I personally put components. They soound alot better but an amp should do the trick
Old Feb 10, 2005 | 12:14 PM
chadfo's Avatar
Most stock speakers can take much more power. They usually sound like crap when you buy the car because they are severley underpowered.
Old Feb 10, 2005 | 04:44 PM
ugly_duck's Avatar
Im definately looking for a little extra bass qithout breaking the bank. Im considering a audioformz but its a bit expensive when i factor in a 10 sub and amp.
I currently have a 12" solo l7 w/ kicker 800.2 and it drained power out of my protege and killed an 90 amp alternator.
Subs are inpractical for my pending child.
Old Feb 12, 2005 | 06:11 PM
scionfiend's Avatar
How is this idea? I have a JL amp which kicks about 45 Watts by 2 RMS. Would you guys recommend I connect the amp to the stock tC front speakers?
Old Feb 12, 2005 | 06:29 PM
chadfo's Avatar
You don't have to lose sound because of children, just a little volume. Bigger is not always better or necessary for subs. You can use 6 1/2" subs that will take up very little room, improve the sound dramatically, and not hurt your child's fragile hearing.
Old Feb 12, 2005 | 06:39 PM
squirrel's Avatar
The first upgrade I did on my stereo was to add an amp and the subs under my front seats. The 4x50 watt Arc Audio amp powered the 2 -10s and my front speakers. They didn't blow. Now I'm running the 4x50 to a set of components and co-axials up front, and to the speakers in the rear. I have a 1k watt powering the 3 - 10s.
SloTC1
Apr 2, 2015 07:11 PM
SuBSiN
Mar 13, 2015 04:02 AM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
1sikxb
Nov 10, 2003 04:01 PM
vpkb
Oct 7, 2003 01:35 AM
