Scion xD ICE & Interior In-car entertainment and electronics...
08 xD Wiring
Old Dec 18, 2009 | 05:48 PM
bwhite's Avatar
Default 08 xD Wiring
I'm not sure anyone here does wiring mods, but this info might help anyone troubleshooting an electrical problem.
2008 Scion xD 4DR HATCHBACK WITH 1.8L ENGINE AND PIONEER® AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery BLUE (+) RADIO HARNESS
Accesory GRAY (+) RADIO HARNESS
Ground WHITE/BLACK (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Dimmer GREEN (-) RADIO HARNESS
LF Speaker (+) PINK
THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
LF Speaker (-) VIOLET
RF Speaker (+) GRAY
THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
RF Speaker (-) YELLOW
LR Speaker (+) BLACK
LR Speaker (-) YELLOW
RR Speaker (+) RED
RR Speaker (-) WHITE
Steering Cntrls YES
Speed Cntrl YES
Radio Security YES
Security
Battery YELLOW (+) IGNITION SWITCH HARNESS
THIS WIRE IS FUSED AT 25 AMPS
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Starter 1 BLACK (+) IGNITION SWITCH HARNESS
THERE ARE TWO BLACK WIRES - TEST TO BE SURE YOU HAVE THE CORRECT TWO WIRES AND THEN POWER THEM BOTH FOR REMOTE START.
All Door Trigger PINK (-) AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH
TO AVOID DOMELIGHT DELAY USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE
Domelight Super PINK (-) AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH
LF Latch RED (-) AT BODY CONTROL MODULE TO BEHIND FUSE PANEL BEHIND DRIVERS SIDE OF DASH
RF Latch GREEN (-) AT BODY CONTROL MODULE TO BEHIND FUSE PANEL BEHIND DRIVERS SIDE OF DASH
LR Latch BLUE (-) AT BODY CONTROL MODULE TO BEHIND FUSE PANEL BEHIND DRIVERS SIDE OF DASH
RR Latch BLUE (-) AT BODY CONTROL MODULE TO BEHIND FUSE PANEL BEHIND DRIVERS SIDE OF DASH
Trunk Trigger LIGHT BLUE (-) AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH
Hood Trigger WHITE (-) AT SWITCH UNDER HOOD
Parking Lights GREEN (+) AT VEHICLE FUSEBOX
30 PIN PLUG PIN #29
Low Crr Pk Lights WHITE (-) AT VEHICLE HEADLIGHT SWITCH
Convenience
Headlights-Lo LIGHT BLUE (-) AT VEHICLE LIGHT SWITCH HARNESS
LF Pk Lt Bulb GREEN (+) AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb GREEN (+) AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb GREEN (+) AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb GRAY (+) AT REAR RIGHT PARKING LIGHT
All Hazrd Lights BLACK (-) AT HAZARD LIGHT SWITCH HARNESS
LF Hazrd Bulb LIGHT GREEN (+) AT FRONT LEFT DIRECTIONAL LIGHT
RF Hazrd Bulb GREEN (+) AT FRONT RIGHT DIRECTIONAL LIGHT
LR Hazrd Bulb LIGHT GREEN (+) AT REAR LEFT DIRECTIONAL LIGHT
RR Hazrd Bulb YELLOW (+) AT REAR RIGHT DIRECTIONAL LIGHT
Wipers-Lo BLUE (-) AT VEHICLE WIPER SWITCH HARNESS
Wipers-Hi YELLOW (-) AT VEHICLE WIPER SWITCH HARNESS
Parking Brake YELLOW (-) AT VEHICLE FUSEBOX
16 PIN PLUG PIN #2
Trnk Release YELLOW (-) AT VEHICLE FUSEBOX UNDER DRIVER DASH
Remote Start
Ignition 2 GREEN (+) IGNITION SWITCH HARNESS
Accessory 1 WHITE (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense YELLOW (-) IGNITION SWITCH HARNESS
Tachometer RED (AC) AT ECM MODULE
Speed Sense VIOLET (AC) RADIO HARNESS
ALSO PIN AT SKID CONTROL ECU UNDER HOOD
30 PIN PLUG PIN #29
Low Crr. Pk Lights WHITE (-) AT VEHICLE HEADLIGHT SWITCH
Brake Lights GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED (+) AT VEHICLE FUSEBOX
30 PIN PLUG PIN #30
Horn LIGHT GREEN (-) AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH
ALSO BLACK IN HARNESS AT STEERING COLUMN
Rear Defrost BLACK
Modules
WIRE LOCATION
Module 1 ECM MODULE - UNDER HOOD ON PASSENGER SIDE FIREWALL
Module 2 SKID CONTROL ECU - UNDER HOOD NEAR BRAKE BOOSTER
Module 3 MAIN BODY ECU - PART OF UNDER DASH FUSE/RELAY BOX ON DRIVER SIDE
Doorlocks/Windows
Power Unlock YELLOW (-) IN HARNESS IN DRIVERS KICKPANEL
TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYINDER, REQUIRES A DOUBLE PULSE TO UNLOCK ALL DOORS.
PowerLock BROWN (-) IN HARNESS IN DRIVERS KICKPANEL
TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER
Driver Mtr Unlock WHITE (REV) IN HARNESS IN DRIVER KICKPANEL
20 PIN PLUG PIN #10
Driver Mtr Lock LIGHT BLUE (REV) IN HARNESS IN DRIVER KICKPANEL
20 PIN PLUG PIN #20
Pas Mtr Unlock TAN (REV) IN HARNESS IN PASSENGER KICKPANEL
Pas Mtr Lock PINK (REV) IN HARNESS IN PASSNEGER KICKPANEL
LF Window Up RED (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
LF Window Dn GREEN (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
RF Window Up WHITE (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
RF Window Dn PINK (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
LR Window Up YELLOW (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
LR Window Dn BLACK (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
RR Window Up RED (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
RR Window Dn GREEN (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
Old Dec 19, 2009 | 03:32 AM
JJGeneral1's Avatar
thanks!!!
Old Apr 8, 2010 | 10:30 PM
xDdub's Avatar
My AC power outlet is not working, probably the fuse for it messed up. Do you know where the fuse is at for the outlet in the fuse box? Thanks.
Old Apr 9, 2010 | 02:13 PM
cobaltbravo's Avatar
Default Re: 08 XD Wiring
you have A/C power in your car? must be a new feature..
Sent from my Droid using Tapatalk
Old Apr 13, 2010 | 03:31 PM
furiousPunch's Avatar
how do you stop the sound that beeps when you dont put your seatbelt on? lol
Old Apr 23, 2010 | 06:38 AM
bwhite's Avatar
Check the 15A ACC Fuse - Owners mnual shows its location.
Rob54Monty
Feb 3, 2023 08:26 PM
RokGoblin
Scion tC 1G ICE & Interior
Aug 11, 2015 05:24 PM
domincnTC
Aug 4, 2015 01:47 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
