View Full Version : EBAY Mufflers
alaharley
02-10-2005, 04:58 PM
Are thise universal mufflers in EBAy worth trying or has anyone had any experience with one, good or bad?
B2FiNiTY
02-10-2005, 07:26 PM
I wouldn't bother with cheap inferior products.
Z34RedSox
02-10-2005, 07:40 PM
well, some of them look pretty cool and for the money if they do what they say, it could be a good buy, I just don't know if it does do what it says
Lonely_Raven
02-10-2005, 07:47 PM
And how long till it rusts and falls off?
crayonBOX
02-10-2005, 07:49 PM
not for performance at all
not to mention, you usually cut your stock muffler, and screw up the ability to reverse it if you dont like it
get one with a silencer; trust me, you'll appriciate that for sure
is your car manual? it will sound decent with manual
if it's automatic, u'll only be another ricer...no offense, but the rythmic humm of a kazoo isnt' pleasing
~tesh
hotbox05
02-10-2005, 08:54 PM
Wow alot of bs getting thrown around here. 90% of them are good quality by a no name company. I've run ebay mufflers on multiple cars for years no problems . just never buy AROSPEED. they are crap. Oh anmd Stainless doesn't rust. If you go with one make yourself a cat back.
Doing what they say. Ok no n/a/ car will get 10hp from just a muffler. At least not nowadays on small econo cars. I love ebay mufflers. This way you can get any style you choose. I have some for sale , just taking up space at my house. If you get a straight through can style muffler pray to whoever it is that you pray to that it has a silencer. Most of the oval bodied mufflers are not as loud. If you cut and re-weld it will be quite quiet because of the stock resonator and stock 1.75 inch exhaust tubing.
Oh and the unpleasant honda sound is mostly because of it being a honda , I've ran identical exhausts on a civic , miata , hyundai and a few others and each having about the same displacement and similar exhaust configuration, the honda's normally sounded like crap while normally the others did not.
oh and if you want to be able to change muffler get a flange put in and for little money you can switch mufflers with your mood.
THE_DON
02-10-2005, 09:03 PM
Word!
-THE DON
B2FiNiTY
02-10-2005, 09:39 PM
If the muffler is straight through, it will most likely be loud even if you have stock piping simply because it is straight through. Although, everyone's definition of loud is different.
Arospeed is just as bad as all those other no name brand mufflers on ebay. Most likely all made from the same place in Asia.
As far as unpleasant sound, it all depends on what type of muffler/resonator setup you are running. If you put a horrible sounding setup that was on a honda and use the exact same layout on a xb, it will sound just as bad for sure.
Even though those mufflers are made of stainless, the insides are the weakness. The material inside often does not hold up to the moisture and heat produced by the engine and through time it will rust and fall apart from the inside out.
For some, it might seem quality but if you spend the extra $ for japanese made off the shelf products you can see the difference immediately.
But for bang for the buck, you can't loose with the generic brands.
bB2NER
02-10-2005, 09:54 PM
Word!
-THE DON
Double WERD :rofl: :rofl: :rofl: It's amazing the BULL that flies around here.
As long as it has one of those baffles and you leave it in they sound quite sweet. It is also a great alternative to those OVERPRICED ready to install ones on the market.
I got one of the 6inch cans with a baffle while at NOPI from Advanced auto for like 40 bucks (just like the ebay ones) Paid my local muffler place 20 bucks to make the connector pipe and I love it. Sounds and looks sweet plus I still have the 200 bucks saved to spend on OTHER mods. :clap:
Edzone_xB
02-10-2005, 10:34 PM
Those are the mufflers that get all nasty and rust....and are on 92 Toyota Sentras with the Tweety bird sticker on it.
bB2NER
02-10-2005, 10:44 PM
IF SO, Then I got a special one. It made it through the winter without one tiny speck of rust. I think that is why it is called STAINLESS STEEL! IMO
OdBox
02-10-2005, 10:45 PM
Can anyone gimme some info on those "remus" mufflers that are on ebay? thanks
hotbox05
02-10-2005, 11:16 PM
Remus is a semi off brand . it is good.
And no arospeed is complete crap .I had it on my bimmer for 3 months and then bam the inner core came loose and rattled.
I have run 6 different ebay mufflers on different cars and have not had any problems yet the one muffler I spent 80.00 on (the arospeed) falls apart and I bought it from a reputable speed shop.
I have run these mufflers on imports , domestics , and even my supra all with absolutely no quality problems.
No rust
No rattles
No appearance problems
and Honda's actually have a different note from the motor.
Believe who you want but even precission muffler axle backs use almost identical mufflers.
As long as the welds are good and the core is high quality you will have no problems.
Out of about 12 ebay mufflers that I personally have bought (for sale or personal use) only 1 or 2 werent of the utmost quality. and as I've said above I've run these cheapo crap whatever you want to call them mufflers on my supra for over 2 years with no problems. And I am 100% confident that the one I put on my xb will last at least 7 years. Probably more. only prob is I like switching styles too much to keep anything on for too long of a time
bB2NER
02-10-2005, 11:21 PM
Somebody has a muffler fetish. LOL
timinaz
02-11-2005, 12:46 AM
Do those eBay mufflers need to be welded on?
bB2NER
02-11-2005, 01:11 AM
The connector pipe needs to be flared to match the stock one then after the correct position is determined weld it to the muffler to make it one piece. Then the 2 hangers need to be welded on then it bolts on just like the stock muffler.
hotbox05
02-11-2005, 02:20 AM
Theres a few ways. make a mating flange and tie it in with stock and you have an axle back
cut and re-weld.
Or the best option .........
Get a custom made cat back , for noise control either re-use the stock resonator or do as I did and use a 20 inch long glasspack and then continue piping to the muffler. The glasspack will sound better but will be louder.
mikochu
02-11-2005, 04:42 AM
Mooooved!
I have a custom resonator-back HKS setup. I went to a muffler shop and got the piping cut from the end of the resonator, back. I opted for 2" piping and they flared it to fit over the resonator's outlet and was welded.
Here is a link to some pics (and sound file) of before (bought it second hand) and after: http://www.mikochu.com/car/hksexhaust/
Blue_Estel
02-20-2005, 06:58 AM
Mikochu,
Is this the exhaust you have? It sounds nice and i want to do this mod...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7955530468&category=33636
~chris
hotbox05
02-20-2005, 07:57 AM
Miko has an actual hks setup , that listing is an offbrand hks style .
alaharley
02-20-2005, 11:12 AM
just so you know, I ended up with a Ractive muffler from Car Domain. I had the local Meineke shop install for $80. It sound perfect. Not too loud but with the lowered tones that I can hear if the subs aren't too loud. Thanks for the advice, other questions to follow as I get some more $$$.
quadoptix
02-20-2005, 07:31 PM
get something decent quit being cheap
mikochu
02-20-2005, 07:39 PM
hotbox05 is right. I have an authentic HKS exhaustc canister. It is JASMA certified (95 db limit in Japan). A friend of mine has a Megan Racing exhaust on his RSX Type S that is the same style as mine, but it sounds much louder. It only sounds like mine when he has his silencer in place.
I think Kaeon has an "eBay exhaust" on his tC. Hit him up for a sound file.
quadoptix
02-21-2005, 05:38 AM
quit braggin miko lol
mikochu
02-21-2005, 06:28 AM
pffffft :ttth:
Anyway... if you want the same exhaust, it's the HKS Silent Hi-Power exhaust (http://www.hks-power.co.jp/products/exhaust/muffler/silent/silent.html). I don't think they sell it in the US... It's soooo JDM... kekekekeke :silly:
quadoptix
02-21-2005, 06:31 AM
:rofl: hey man, why do u keep going on about it huh :loser: :P
mikochu
02-21-2005, 06:34 AM
because unlike your body kit, my exhaust was actually made in Japan...
BURRRRRRRRN!
okay...that's enough (at least from me...) :lalala:
quadoptix
02-21-2005, 06:35 AM
woooo at least i got a body kit...and big brakes n rims n etc etc etc etc. =P
djct_watt
02-21-2005, 07:07 AM
:doh: I ain't got sheeeeeet. :doh:
