Clutch Plate
Old Jan 1, 2010 | 05:29 PM
skygtrr32's Avatar
Default Clutch Plate
What can happen if your clutch plate is not torqued down to properly.
Old Jan 1, 2010 | 05:50 PM
draxcaliber's Avatar
well...if something is under torqued...it would come loose...and if something is over torqued...it usually cracks or breaks. why?
Old Jan 1, 2010 | 06:02 PM
skygtrr32's Avatar
I am doing a clutch change on my car, Im half way bolting every thing back up. So for some odd reason then I asked my friend what he tq the clutch plate to, he told me he tq it to 70 inch pounds when it needs to be tq to 168 inch pounds.
Old Jan 1, 2010 | 08:17 PM
skygtrr32's Avatar
So should I take everything off agian a tq down clutch plate, since Im half way done with the bolting things back up.
Old Jan 1, 2010 | 08:20 PM
TJKASS's Avatar
The plate will vibrate at its resonant harmonics everytime you engage it, and over time, those bolts will come loose because of that until one falls out and gets wedged in the pressure plate and gouges the hell out of everything. Yes, 70 in/lbs is too low. it needs to be between 14 and 15 ft/lb or 168 in/lbs or you will almost certainly have issues and theyll usually be terminal issues at that.
Old Jan 1, 2010 | 08:22 PM
TJKASS's Avatar
Yeah just take it off and retorque it and youll be fine. I know its a pain but youll thank yourself in the long run.
Old Jan 1, 2010 | 08:37 PM
skygtrr32's Avatar
thanks for the info
Old Jan 1, 2010 | 08:55 PM
TJKASS's Avatar
NP if you have any other trans or clutch questions/issues feel free to ask.
Old Feb 1, 2010 | 12:54 PM
trungchau's Avatar
sorry to jack but I have a question.
I am driving the other night and all of a sudden my car won't stay in fifth gear
1-4 and R are fine with no slipping
once I put it in 5th and gas, it slips to N
my guess is the pressure plate is bad
I have another clutch and prssure plate ready to install
just making sure that seems to be the problem before I go through with placing that and having it be the tranny
I figured if it were the tranny that Iwould here grinding and that the first 4 gears would have issues too, not only 5th
a23r
Feb 1, 2016 04:05 AM
Darrenohooligan
Sep 26, 2015 07:21 AM
carbinefreak
Sep 24, 2015 02:06 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
Subaru86
Sep 14, 2015 12:43 PM
