mikochu
02-11-2005, 09:07 PM
In this tutorial, I will be installing the Fantasy Creations, Inc.'s "Fatty S" brushed stainless steel grill onto 2tone_xB's xB. The "Fatty S" brushed stainless steel grill is one of many grills available at Fantasy Creations, Inc. (http://www.fantasy-creations.net/) I would like to thank Dan Gross at Fantasy Creations for providing the grill for this install. I would also like to thank Zach (2tone_xB) for letting me use his car for this tutorial.
Out of the box, you will find an instruction manual, an FC pamphlet, and the grill. The grill is packed into the box nicely with a generous amount of bubble wrap.
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/01.jpg
Fantasy Creations "Fatty S" grill includes an anodized aluminum mesh grill (black) behind the stainless steel grill.
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/02.jpg
The installation of the Fantasy Creations grill is very easy. It should take less than 10 minutes to uninstall the current grill and install the FC grill. It took me about 4 minutes from start to finish. However, I do not suggest you rush the installation.
Tools needed:
- Small flathead screwdriver
Optional:
- Fender mat (or any non-abrasive mat)
1. First, you want to pop the hood open and prop it up using the hood rod.
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/03.jpg
***If you have a fender mat, put it over the work area (front bumper).***
2. Locate the 3 plastic (black) fasteners that hold the stock grill in place.
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/04.jpg
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/05.jpg
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/06.jpg
3. Using the small flathead screwdriver, pop out the fasteners by prying the top portion away from the bottom.
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/07.jpg
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/08.jpg
***I suggest you take the left and right fasteners out first, then hold the stock grill as you pop out the middle fastener. The grill may just fall off, otherwise.***
Once the stock grill is uninstalled, place it somewhere safe.
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/09.jpg
4. Take the Fantasy Creations grill and carefully insert the left "L" shaped tab into the existing slot.
5. While carefully flexing the grill along the contour of the top of the bumper, insert the second tab into the designated slot.
6. Once both tabs are inserted into their designated slots, line up the upper tabs and insert two of the fasteners. Make sure the fasteners and upper tabs are resting flush on the mounting holes before securing the fastener.
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/10.jpg
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/11.jpg
The third fastener is not used and should be stored in a safe place, along with the stock grill.
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/12.jpg
Once the two fasteners are locked, you are done! Double-check everything before closing the hood and going for a drive.
Care of your grill
Fantasy Creations, Inc. recommends Stoner Invisible Glass and a clean dry micro fiber cloth for cleaning your mirror finish stainless steel grill. Stoner products can be found at most Target stores or on the web at www.stonersolutions.com.
Brushed finish stainless steel grills can be cleaned with isopropyl (Rubbing Alcohol) and a soft cloth.
Here are some pics of 2tone_xB's ride sporting the grill.
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/13.jpg
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/14.jpg
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/15.jpg
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/16.jpg
http://www.scionlife.com/tech/images/fattysgrillinstall_xb/17.jpg
If you have any questions, please post here, pm, or email me.
Tools needed:
Optional:
Care of your grill
