v-train
01-18-2010, 01:20 PM
i installed my injen intake i bought it without the instructions. everything was fine and simple (except puting the lower intake through the fender which was a pain in the ___) and i ran across a little problem im not sure where to put the mounting bracket for the lower intake am i suppose to use the headlight ground bolt? cause thats about the only close place close to the intake after installin it. so far i just thuglifed it and ziptied the ____. heres a pic
ack154
01-18-2010, 01:30 PM
The instructions tell you to relocate that ground wire and use that location to mount the intake with one of the "vibramounts" they give you.
v-train
01-18-2010, 01:43 PM
mm ic thanks where would you recommend i relocate the ground to?
GammaTNT
01-18-2010, 01:47 PM
http://www.scionlife.com/tech/images/injen_cai_tc/P2090099.jpg
hydralover
01-18-2010, 07:33 PM
Pretty sure you can keep the bolt there... Just make sure it's grounded (touching the metal). That's what I did, without any problems.
Xx AzN xX
01-19-2010, 08:31 PM
yeah i just kept mines in the same place between the metal and the vibramount
