JasonH
02-12-2005, 08:23 PM
I finally got around to installing the auto dimming mirror today. I bought it from McGeorge Parts (http://www.mcgeorgeparts.com) a few months ago. Before I began, I needed to track down the installation instructions (not sure where mine went.) I found them here (http://www.toyotaparts4u.com/installation_manuals.htm). In reading through them, I found something interesting. While the original instructions had you remove the driver's side visor and A-pillar cover then tap into the fusebox, these new instructions have you tap into the overhead console and sunroof wiring. This made the installation much easier than I thought it would be. This would also allow anybody with the side air bags to install the mirror with no trouble.
This is the easiest factory accessory I've installed since the side sills. It requires only one tool really, a Torx screwdriver to tighten the screw on the mirror. The instructions are well written and easy to follow. Basically, here's how you do it:
First, you remove the stock mirror. The instructions tell you to pull it straight down to pull the complete mirror assembly off the windshield. When I did this, I pulled the mirror part off of the arm. It was still easy to pull the remaining part off of the windshield, but pulling it towards me (rather than straight down) seemed to work a little better. You then remove the overhead light assembly either using a plastic panel removal tool, or a combination of your fingers and some other kind of plastic tool (I used a plastic bicycle tire lever.) It will take a good deal of force to pull it out, and you might end up with a couple of the white plastic fasteners still attached to the roof sheet metal. Remove them with a pliers or something, but don't damage them, since you'll need them to reattach the light assembly. Disconnect the wiring harness from the light. When that's all done, this is what it will look like:
http://www.scionlife.com/tech/images/autodimmingmirror/01s.jpg (http://www.scionlife.com/tech/images/autodimmingmirror/01.jpg) http://www.scionlife.com/tech/images/autodimmingmirror/02s.jpg (http://www.scionlife.com/tech/images/autodimmingmirror/02.jpg) http://www.scionlife.com/tech/images/autodimmingmirror/03s.jpg (http://www.scionlife.com/tech/images/autodimmingmirror/03.jpg) http://www.scionlife.com/tech/images/autodimmingmirror/04s.jpg (http://www.scionlife.com/tech/images/autodimmingmirror/04.jpg)
You then plug the wiring harness into the mirror, mount the mirror, tighten the screw with the Torx screwdriver, then route the wire into the headliner at the top of the windshield. There is a clip to secure the wiring to the mirror arm, and a cover that runs from the mirror mount to the headliner. It makes for a clean look when it's all done.
http://www.scionlife.com/tech/images/autodimmingmirror/05s.jpg (http://www.scionlife.com/tech/images/autodimmingmirror/05.jpg)
Once the wiring is coming out of the headliner hole, you need to attach the T-taps to the existing wiring. 2 taps go onto the overhead console harness, and one to the sunroof harness. Pull both of the harnesses out of the headliner and pull back the tape on the wires so you can work with them. Try to stagger the T-taps so they don't get all bunched up. Follow the instructions on which wires connect where. It's pretty easy if you pay attention. My wiring harness was long enough to run down to the fusebox (I don't know if new mirror kits are the same way) so I had many feet of extra wire. I decided not to cut out any of the wire, so I bunched it up with a zip tie, wrapped some foam tape around it, the shoved it into the headliner space.
http://www.scionlife.com/tech/images/autodimmingmirror/06s.jpg (http://www.scionlife.com/tech/images/autodimmingmirror/06.jpg) http://www.scionlife.com/tech/images/autodimmingmirror/07s.jpg (http://www.scionlife.com/tech/images/autodimmingmirror/07.jpg)
Reconnect the harnesses, then reattach the overhead light assembly. Make sure your wires are all tucked into the headliner, and that they don't interfere with the clips that hold the light assembly in. I needed to give the assembly a couple of extra pushes to get it seated correctly and nice and tight. Here's a pic of everything complete:
http://www.scionlife.com/tech/images/autodimmingmirror/08s.jpg (http://www.scionlife.com/tech/images/autodimmingmirror/08.jpg)
The mirror surface itself seems bigger than the stock one. The auto-dimming feature is kind of neat - when you cover the sensor the mirror takes on a blue-ish tint. The multicolored lights are cool too, but it's not dark yet so I can only tell you they work, and not how bright they are. I haven't been successful in programming my garage door opener into it yet, but I think I need ne batteries in my transmitter.
That's it! I hope you enjoyed this how-to. Check out McGeorge Parts (http://www.mcgeorgeparts.com) if you want to get a mirror of your own.
