09 Sub w/ Aftermarket HU?
Hey ive run into a 09 sub that goes underneath the trunk mat, im just wondering if theres anyway to make that work with an aftermarket headunit because i know someone said its like plug and play but has anyone gotten it wired up to work with an aftermarket HU in an 06?
in the 08-10 tc's, the subwoofer's signal is recieved from the front speakers. since you don't have that year, you don't have the harness.
if you want to use the amp that is connected to the whole assembly...your best bet is to go to a junk yard and see if you can get a subwoofer harness out of a 08-10 tc. then find someone who has a 08-10 tc, that will allow you to use a DMM (digital multimeter) to determine which wires are which. you would then run rca cables but get an RCA pigtail (goes from rca plug to bare wire, you can make your own, just strip a rca cable), to the appropriate + - wires in the harness.
if you don't want to use the factory harness/amp, i would just go get a small amp and run the subwoofer straight off that. i believe it's only like a 35w amp.
BlingSlade
Nov 20, 2015 06:56 PM
kslim619
Sep 18, 2015 06:54 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
