bumper height
Old Jan 21, 2010 | 12:09 AM
zim6699's Avatar
Default bumper height
got pulled over the other day for being to low to the ground.... bs... but i was wondering if anyone knows where online u can find technical info on the xb like the actual height of the front bumper?... thnks
Old Jan 21, 2010 | 12:38 AM
EAmon's Avatar
i think when i lowered my car on my goldlines the height was 6" or 6.5" above the ground. so stock height should be like 8" off the ground
Old Jan 21, 2010 | 02:48 AM
Jiggaman's Avatar
Big Sky Scion
for being too low? my god i am glad the cops dont harass you for ANY car mods here...except when you play your music "too loud" ....pfffff
whats the law for that kind of thing where you are?
Old Jan 21, 2010 | 02:55 AM
daneisthegreatest's Avatar
wow, stock they are 8" off the ground? i didnt know mine was dropped so low, mine is 2 1/4" off the ground
Old Jan 21, 2010 | 02:57 AM
sdsnybny's Avatar
Technically the crash bar under the front cover is the "bumper" and if you lowered it to much for your state regulations they might have you. Also some states restrict how far any part of the car can be from the ground, added on or otherwise. Check online for your states Vehicle Codes it will be in there.
Old Jan 21, 2010 | 03:57 AM
RedneckwithanxB's Avatar
Actually I believe that what your talking about refers to headlight height to the ground, making your car hard to see at night... or something along those lines... got pulled over in GA for it once, and well... the highway pig didnt like when i hit a switch and aired the car up...
Old Jan 21, 2010 | 04:42 AM
Tomas's Avatar
Admin Emeritus
Each state has its own requirements for bumper height and penalties (or lack of) for vehicles that do not meet the requirements, BUT the requirements must all start with the Federal requirements in 49 CFR Part 581: The bumper on a passenger vehicle must protect the area between 16 and 20 inches above the ground.
States also have their own individual requirements for minimum height of the chassis above the ground, but most of them require that no part of the chassis can be lower than the height of the wheel rims above the ground...
(Some states also have other requirements like no part of the body or chassis within "x" inches of the ground - often two inches.)
In this state they used to set a 4 foot long two by four crosswise in front of the car, flat on the ground, and have you drive over it. If the 2x4 moved, you were ticketed.
HTH
SentraSE-R's Avatar
What are the bumper height laws in the state of Virginia?
Section 46.2-1063 states:
Alteration of suspension system; bumper height limits; raising body above frame rail. -- No person shall drive on a public highway any motor vehicle registered as a passenger motor vehicle if it has been modified by alteration of its altitude from the ground to the extent that its bumpers, measured to any point on the lower edge of the main horizontal bumper bar, exclusive of any bumper guards, are not within the range of fourteen inches to twenty-two inches above the ground. Notwithstanding the foregoing provisions of this section, the range of bumper heights for motor vehicles bearing street rod license plates issued pursuant to § 46.2-747 shall be nine to twenty-two inches.
No vehicle shall be modified to cause the vehicle body or chassis to come in contact with the ground, expose the fuel tank to damage from collision, or cause the wheels to come in contact with the body under normal operation. No part of the original suspension system of a motor vehicle shall be disconnected to defeat the safe operation of its suspension system. However, nothing contained in this section shall prevent the installation of heavy duty equipment, including shock absorbers and overload springs. Nothing contained in this section shall prohibit the driving on a public highway of a motor vehicle with normal wear to the suspension system if such normal wear does not adversely affect the control of the vehicle.
No person shall drive on a public highway any motor vehicle registered as a truck if it has been modified by alteration of its altitude from the ground to the extent that its bumpers, measured to any point on the lower edge of the main horizontal bumper bar, exclusive of any bumper guards, do not fall within the limits specified herein for its gross vehicle weight rating category. The front bumper height of trucks whose gross vehicle weight ratings are 4,500 pounds or less shall be no less than 14 inches and no more than 28 inches, and their rear bumper height shall be no less than 14 inches and no more than 28 inches. The front bumper height of trucks whose gross vehicle weight ratings are 4,501 pounds to 7,500 pounds shall be no less than 14 inches and no more than 29 inches, and their rear bumper height shall be no less than 14 inches and no more than 30 inches. The front bumper height of trucks whose gross vehicle weight ratings are 7,501 pounds to 15,000 pounds shall be no less than 14 inches and no more than 30 inches, and their rear bumper height shall be no less than 14 inches and no more than 31 inches. Bumper height limitations contained in this section shall not apply to trucks with gross vehicle weight ratings in excess of 15,000 pounds. For the purpose of this section, "truck" includes pickup and panel trucks, and "gross vehicle weight ratings" means manufacturer's gross vehicle weight ratings established for that vehicle as indicated by a number, plate, sticker, decal, or other device affixed to the vehicle by its manufacturer.
In the absence of bumpers, and in cases where bumper heights have been lowered, height measurements under the foregoing provisions of this section shall be made to the bottom of the frame rail. However, if bumper heights have been raised, height measurements under the foregoing provisions of this section shall be made to the bottom of the main horizontal bumper bar.
No vehicle shall be operated on a public highway if it has been modified by any means so as to raise its body more than three inches, in addition to any manufacturer's spacers and bushings, above the vehicle's frame rail or manufacturer's attachment points on the frame rail.
This section shall not apply to specially designed or modified motor vehicles when driven off the public highways in races and similar events. Such motor vehicles may be lawfully towed on the highways of the Commonwealth.
Old Jan 27, 2010 | 08:43 AM
bB2NER's Avatar
Music City Scions
So basically if you don't drag the ground you should be OK.
I'd just throw the stock springs on, then take it to be signed off by a cop and mail the ticket back in. It is a fix it ticket right?
It's really too bad that cops don't have better things to do than harrass people with nice vehicles.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
hondajt
Dec 14, 2015 12:54 PM
Schmohey
Oct 4, 2015 02:53 PM
jeremydoc
Sep 16, 2015 11:31 PM
prescottn
Sep 13, 2015 09:04 PM
