Anybody added sensors to Scion Security?
Old Jan 22, 2010 | 03:52 AM
TrevorS's Avatar
Default Anybody added sensors to Scion Security?
Got a couple questions regarding the Scion Security system. When it's active does it detect hood release and fire the alarm? I don't see that in the list of post install tests.
Second question, is there any info on the best way to connect an additional sensor (say tilt or impact)?
Seems to me, if there's a hood release sensor (pin switch), then its signal wire could be used to add additional sensors. If there's not, then any info? I guess the glass sensor signal wire could also be shared, though I haven't found any wiring detail yet on either the Scion Glass Break Sensor or the Security ECU.
Anybody got any experience with this?
Thanks -- Trevor
Old Jan 22, 2010 | 11:03 PM
TrevorS's Avatar
I've learned the Scion Security system doesn't trigger upon hood release. And looking closely at the latch assembly on my 2008, there's no sign of a pin switch that could detect it. So, I guess that's a miss I would like to fix, but it's also an indication that sharing the Scion Glass Break sensor wire is probably the only possibility for adding sensors.
Again, does anybody have any experience with this?
Old Jan 22, 2010 | 11:06 PM
SquallLHeart's Avatar
you can't add anything. unless you add another alarm system in there.
Old Jan 23, 2010 | 02:28 AM
TrevorS's Avatar
Do you know why that is? I guess if the Glass Break Sensor uses pulse signals or the CAN it would mess it up, but if DC, then I would have thought that would work fine using diodes to separate the sensors.
streetracerr
Jul 11, 2015 09:52 PM
daniinpitt
Apr 4, 2015 08:07 PM
DAHOZZMAN
Dec 16, 2014 06:48 AM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
crocker
Dec 2, 2014 03:44 AM
