FML low oil pressure
Old Jan 23, 2010 | 02:37 PM
cburglb34's Avatar
Default FML low oil pressure
ok well usually my oil pressure after some spirited runs is 8-11 psi at idle....
yesterday it started idling at around 5-7psi at idle....
but... my cruising and cold start oil pressures are normal
my guesses....
either
1. its cuz i just got an oil change and the oil is thinner than the old oil i had..
2. rtv is clogged around my oil pick up tube
3. oil pick up tube is loose ( i did reinstall this recently)
so i guess monday ill drop the oil pan and take a looky
this car is nothing and i mean NOTHING BUT PROBLEMS....because of this i went out and bought a 2010 ford edge fully built for my daily driver
Old Jan 23, 2010 | 02:58 PM
Ace83's Avatar
Ronin Scion
oil level and idle rpm the normal? how thin is your oil now?
Old Jan 23, 2010 | 03:05 PM
cburglb34's Avatar
oil level is spot on... now the idle rpm i cant really tell ill have to hook up my aem to it what normal idle like 700-720 right? cruising town and after long drive pressure is at 11-8psi
oil weight is 10w30 penzoil synthetic
wont hurt for me to drop it anyways i wanna make sure i tq the oil pickup bolts to spec when i did it 2 weeks ago i tighten 1 tight and the other i tightened just as much but felt that it coulda gone more but didnt wanna run risk of stripping it
Old Jan 23, 2010 | 03:08 PM
Ace83's Avatar
Ronin Scion
the only time i had an oil pressure of 5 psi on hot idle was when my rpm was surging down to 500rpm... wouldnt hurt to check though
Old Jan 23, 2010 | 03:16 PM
cburglb34's Avatar
nope wouldnt hurt at all cept for the new oil and toyo FIPG i gotta buy lol
ill re-use my oil filter its got like 400 miles on it
Old Jan 23, 2010 | 03:19 PM
ElevationTC's Avatar
I got stock on yota fipg
Old Jan 23, 2010 | 03:30 PM
cburglb34's Avatar
lol its the best stuff out there nothing seal better...
the permatex red is too runny and thing, the right stuff stick well for maybe 3 months and then theres the other wanna be stuff
nothing compares to FIPG
Old Jan 23, 2010 | 03:43 PM
cburglb34's Avatar
ok well just got off the phone with ptuning... they will take care of it for me i dont wanna drop this oil pan anymore on my own
Old Jan 23, 2010 | 03:54 PM
coryjames's Avatar
the car is nothing but problems cause you have taken mad shortcuts in the past and the car has had alot of things off and on
Old Jan 23, 2010 | 04:06 PM
cburglb34's Avatar
yes this is true, BUT just when i thought i had everything perfect and no shortcutted...this crap happens to me
Old Jan 23, 2010 | 05:09 PM
crush02342002's Avatar
I used the same oil except i used 5w20 and had a oil cooler, your oil pressure does seem a touch low but not real bad. still there is something up, i too would like to hear what your idle rpm is.
Old Jan 23, 2010 | 10:15 PM
cburglb34's Avatar
k idle rpm is anywhere form 770-700
Old Jan 24, 2010 | 12:37 AM
that isnt good...maybe not dire but its not good.
Old Jan 24, 2010 | 05:14 AM
cburglb34's Avatar
oil pressure or the idle rpm?
oil pressure will be taken care of
Old Jan 25, 2010 | 05:27 PM
DezodDon's Avatar
Typically the rule of thumb is 10 psi for every 1000 rpm.
Old Jan 25, 2010 | 07:39 PM
cburglb34's Avatar
thanks don so having a 7psi pressure around 700 rpms isnt NORMAL but not DRASTIC... ill have it fixed up soon
Old Jan 25, 2010 | 08:19 PM
DezodDon's Avatar
Factory service manual states that at idle minimum pressure is 4.3psi.
If you don't hear a knock or your oil pressure light isn't on then I would be inclined to say that you are fine.
At 3000 rpm the book states anywhere between 36-78 psi is normal.
Old Jan 25, 2010 | 08:23 PM
CarbonXe's Avatar
My oil pressure dropped to ~5 on multiple occasions when coming to a stop (gauge warning was set to 5PSI). I never really considered it a problem as it usually bounced back up to the usual 7-10.
Old Jan 25, 2010 | 08:51 PM
WTF my motor has 30 psi at idle lolz 60+ when cold..
thats with 10-40
Old Jan 25, 2010 | 09:43 PM
cburglb34's Avatar
thats with 10-40
your built silly
DaBlackBox
134
Apr 10, 2022 02:04 PM
my06tc
Jun 25, 2015 12:18 AM
eric_m
79
Mar 17, 2013 12:21 AM
