i need someones helppppp......
Old Jan 25, 2010 | 06:05 AM
speedintc's Avatar
Default i need someones helppppp......
so i installed my apt fog lights, wired them all up cut them on they worked fine but when i started the car they went out. i checked every fuse and none are blown, and also my gauge cluster lights went out as well. also my 12v outlet in my center console stopped working as well. can someone please give me some feedback? i even downloaded the electrical manual but i really cant figure this out.
Old Jan 25, 2010 | 08:52 AM
Dkfung88's Avatar
sounds like a fuse.... check ur fuse box and see if u can find a map in there for the interior.
Old Jan 25, 2010 | 02:57 PM
cobaltbravo's Avatar
Should of had me do them while you were up here Patrick...
Old Jan 25, 2010 | 05:56 PM
speedintc's Avatar
dj i checked every single fuse interior and under the hood nothing is blown.
and cobalt i didnt have them when i was in de. and it wasnt hard to install especially how they jus plug into the factory harness.
Old Jan 25, 2010 | 07:55 PM
lyricalmind24's Avatar
good way to kick him when hes down lol
Old Jan 26, 2010 | 02:26 AM
wazzu_coug's Avatar
not trying to be a d*ck...but it's a blown fuse. go back and check them again.
Old Jan 26, 2010 | 02:37 AM
BZinn1's Avatar
for all those items to have gone down it is a fuse.....mine did same thing,but i dont remember what fuse it was.....but it is there.
Old Jan 26, 2010 | 02:46 AM
bdis3's Avatar
re-check the fuses, all your connections, and maybe your H.I.D. ballasts. sounds like a fuse to me though.
Old Jan 26, 2010 | 05:48 AM
speedintc's Avatar
guys i promise i pulled every single fuse out like a thousand times tryin to figure this out and none were blown, and bdis i decided not to put the hids in yet.
Old Jan 26, 2010 | 06:06 AM
donnyp05tc's Avatar
take a test light and test each fuse separately. A fuse can be bad without it blowing or breaking. For them all to go out like that, it has to be a fuse.
Take the test light and ground it out, then touch it to the top of each metal circle of every fuse. Their is 2 per fuse. If it lights up then its good, if not, then its bad.
I would check all fuses under the hood and interior. Let me know how this works. Otherwise I can have you try other things
Old Jan 26, 2010 | 06:44 AM
speedintc's Avatar
ok i didnt atcually test the fuses that way, but there is one wire that goes to the harness that connects to the foglight switch that isnt gettin power as well. what other things could i possible do? im gonna go take a picture of the the harness that im talking about.
Old Jan 27, 2010 | 11:29 PM
wazzu_coug's Avatar
that wire is the power wire. it's not getting any power because the fuse is blown.
stop asking for help then refusing to accept the (correct) answers provided.
Old Jan 27, 2010 | 11:41 PM
SquallLHeart's Avatar
you blew the PANEL fuse.
though for your armrest power outlet.. that's another fuse too.. it's not related to the fogs.. so i don't know what you did.
the back of the manual show you what fuses to check.
there's no need to check every single fuse.. that's just pointless and wastes time
Old Jan 28, 2010 | 08:38 PM
donnyp05tc's Avatar
^^^ agreed, I was just giving him a tip on how to test his fuses. I would check the manual and find what fuse is blown and just replace that one like squallLheart stated.
Much easier!
yhwhdesign
Jun 11, 2021 03:34 PM
crimson10tC
Sep 10, 2015 08:44 PM
jbernard
Aug 22, 2015 09:14 PM
Forced4
Aug 21, 2015 09:22 PM
5N1PE5
Aug 3, 2015 11:25 AM
