Got APT's Fogs! [Need Help w/Bulbs]
Old Jan 25, 2010 | 04:40 PM
SighOnPhresh's Avatar
Default Got APT's Fogs! [Need Help w/Bulbs]
So i've been around this forum for months now. and I'm a newbie when it gets to modding. lol. and all i have are HID's for my low beams and some LED bulb swaps.
Getting the APT fog lights today on Ebay! and of course im going for the yellow lights =]
and another help [even though the instructions are sent]
with the installation of these lights.
do i HAVE to remove the front bumper?
(I know its plug n play...)
now, i was wondering if u guys could help me out with the best bulb.
dont really know the diff between the 2.5 and 3k output.
and kinda shady with what stage 1 and all that means.
so all input will help
thanks in advance!
~Markayyyy
Old Jan 25, 2010 | 05:20 PM
ecko04's Avatar
thanks in advance!
~Markayyyy
If you have a turbo, there is no need to remove the bumper because chances are all of your undercarriage guards are removed. Otherwise you will need to remove the bumper to do the install correctly. They are plug-n-play once you remove the bumper
Old Jan 25, 2010 | 05:22 PM
Aphex13's Avatar
You could remove the liners under your car and get to them that way, but trust me... It's easier to just take the bumper off.
Old Jan 25, 2010 | 05:25 PM
juzlookzfazt's Avatar
As said above, removing the bumper would make it easier, or at-least it was for me lol. Some people just unbolt the splashguards at the bottom and reach up under from there, some do it through the splashshield in the wheel well. I don't like to stretch or bend anything on my car, so I just removed the bumper to install mine.
Old Jan 25, 2010 | 05:28 PM
TCpete's Avatar
take off the splash gaurds...
taking the bumper off is over kill!!!!!!! to much work for a little task... the black splush guards underneath removed is more then enough room
Old Jan 25, 2010 | 05:30 PM
He might as well get acquainted with removing the bumper now since he's new to modding lol.
Old Jan 25, 2010 | 05:34 PM
DJ08tC's Avatar
the first time i put mine in i took the splash guard off, when i changed my bulbs i just took a couple of the bolts off and put my hand up there and pushed them out.
Old Jan 25, 2010 | 06:00 PM
aww man i was hoping to avoid removing it.
deng i suck at that sorta stuff lol..
but about the bulb color, i see some on ebay which ones should i buy.
yellow for sure but...
iunno.
2500k nokya's right?
Old Jan 25, 2010 | 06:26 PM
DJ08tC's Avatar
H3 nokya 2500k bulbs
Old Jan 25, 2010 | 06:38 PM
ecko04's Avatar
If you have to run the harness just take the bumper off, you're not used to doing this stuff so taking shortcuts is not to your advantage
Old Jan 26, 2010 | 12:10 AM
minter66's Avatar
Just do what I am going to do. Save for EVERYTHING.
I did my TSX Retrofit - Ready
New D2S Hid Kit and wiring - Ready
I just received my VRD grills - Ready
I am saving for my APT fogs - Not Ready
Once it's all done, take the bumper off ONCE and do four things at once.
Old Jan 26, 2010 | 03:27 AM
kk guys thanks for the feedback
still iffy on removing the bumper but really appreciate all your guys' comments.
Old Jan 26, 2010 | 03:44 AM
Uyles's Avatar
I just put my APT's on like two hours ago.
Just remove the splash guards under the bumper, you'll be fine. I've never done electrical or anything and it wasn't hard to figure out what was going on.
You basically just need to ground it and connect the harness and then find out places to run the wires so it looks clean. It's cake, honestly.
Old Jan 26, 2010 | 03:49 AM
oh wow that was a relieving response lol.
thanks!
and as far as grounding it goes what does that mean?
im sorry to be so full of questions and all ( el oh el )
Old Jan 26, 2010 | 05:04 AM
ZTC's Avatar
ZTC
There will be a ground wire on your kit, its usually a black wire with a ring terminal connected to the end. or it will say ground, -, something lol. that wire needs to be connected to the frame of the car. if you can spot a bolt on the body with wires connected to it then just add your wire to that bolt and re tighten it back.
Old Jan 26, 2010 | 07:41 AM
cool so just jack up my car.
WITHOUT removing theeeeeeeeeee bumperrrr
push out those black things lol.
then boom?
sounds good!
also i see 2500k nokyas on ebay should i get?
any BIG diff between 2500 and 3000?
Old Jan 26, 2010 | 03:42 PM
DJ08tC's Avatar
get nokya 2500 bulbs if you want yellow
Old Jan 26, 2010 | 05:39 PM
Cadilak78's Avatar
I've done both methods when I had some foglight issues. Since I've switched fogs a few times and bulbs (regular bulbs to HID's and Nokya's on the way) I just jack up the front end and take off the splash guards. I've seen some people use those ramp stands, which would probably be the best thing to use. Either way it is a simple install to do. Good luck!
Old Jan 26, 2010 | 09:28 PM
thanks a lot man.
cute cat btw.
Old Jan 26, 2010 | 09:31 PM
omgu8myrice's Avatar
just jack up the car, and take off the guards underneath like people have said...easy to just reach through.
