Tailight condensation? and exhaust question
Old Feb 17, 2010 | 01:22 AM
diego_demarco1025's Avatar
Default Tailight condensation? and exhaust question
Alright so i have tyc tails and i washed my car on saturday and now i have a little bit of condensation in one of the lights, how do i remove that?
My 2nd question is my exhaust setup right now is a
No name short ram intake,
megan midpipe with a resonator
and an injen ses exhaust
im getting tired of the exhaust so i was thinking if having the megan midpipe actually makes it louder or quieter, also if i add an aftermarket s-pipe will it be louder or quieter
Old Feb 17, 2010 | 01:59 AM
bumpp
Old Feb 17, 2010 | 02:16 AM
sw09's Avatar
check the rear rotors/pads. if its metal on metal you need pads and rotors. feel the rotors too, if they feel really bumpy you can get them resurfaced, but youll be better off getting new ones.
Old Feb 17, 2010 | 02:34 AM
and if the rotors are fine should i just get new oem pads
Old Feb 17, 2010 | 02:54 AM
crg5990's Avatar
just try new pads in the back. and as far as your exhaust an aftermarket s-pipe wont really make much of a volume/pitch difference
Old Feb 17, 2010 | 03:12 AM
what if i take off the midpipe and put on the stock midpipe, would that make it louder or quieter
Old Feb 17, 2010 | 03:58 AM
rangerryda's Avatar
stock mid pipe will quiet things down considering it has an additional cat and a huge resonator. The S-Pipe would make things a little deeper because the factory is a double wall construction on the bendy portions and does a fair amount of sound deadening. I noticed this when I cut my factory one up before putting on my megan.
Old Feb 17, 2010 | 02:26 PM
ooo ok thanks
Old Feb 17, 2010 | 02:55 PM
rangerryda's Avatar
http://www.mandrelexhaustsystems.com...EXHAUST/Detail
cheap and effective s pipes
Old Feb 17, 2010 | 10:29 PM
sw09's Avatar
yea if the rotors are good just put new pads
Old Feb 18, 2010 | 01:24 AM
ok and another question is i have tyc tails and one of them has a little bit of condensation in it after i washed my car, how do i remove that
Old Feb 18, 2010 | 04:16 AM
rangerryda's Avatar
It should just go away within a few mins. If it stays and water accumulates over time, then you should take it off the car, take out the bulbs and bake it at a low temp to dry out the air inside and reinstall + pray.
Old Feb 18, 2010 | 05:04 AM
ooo damn and what if it doesnt go away because its been 2 days already, can it affect anything
Old Feb 18, 2010 | 02:39 PM
bump
Old Feb 18, 2010 | 03:31 PM
rangerryda's Avatar
Not really, just appearance. If your car is under warranty, take it to the dealer and they should replace for free.
Old Feb 18, 2010 | 03:42 PM
rougenite's Avatar
If it continues to get foggy and you are not under warranty anymore...bake them and reseal I had a set of headlights from ebay that I had to redo....only took aobut 2.5 hours to do both.
Old Feb 18, 2010 | 08:25 PM
hmm dont know if i want to bake them lol
Old Feb 18, 2010 | 09:40 PM
bummp
Old Feb 18, 2010 | 10:19 PM
BRUIN's Avatar
I just got new ones, i was afraid that it might attack the wiring and screw everything up. My bro that works for toyota hooked me up with some used ones. he said that happens when the housing of the tail light is not sealed all the way.
Old Feb 18, 2010 | 10:46 PM
sw09's Avatar
might be a bit hard to replace TYC ones at the dealer...id say bake it at a low temp and reseal it
