View Full Version : shift knob for automatic
Fujiz_xb
02-15-2005, 03:42 PM
will the following item work for automatic?
it says univeral but our button is on the side.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7953786094&category=33703
Lonely_Raven
02-15-2005, 03:52 PM
I think the way the side button works, is that it pushes a
shaft with a plastic nub at the end that's cut at a 45 degree
angle. So technically the button is verticle under your stock
knob.
Take your stock one off and see before you order me thinks.
SWiSS
02-15-2005, 04:02 PM
that would be sick! IM not sure either though. wish i could be of more help...
GINNJUICE
02-15-2005, 04:05 PM
i think it would work but how about the overdrive button.
Fujiz_xb
02-15-2005, 04:06 PM
over drive? do we even need that?
dirtysocks
02-15-2005, 04:14 PM
i got one of thoses along time ago and do you think it could work as a ebrake knob i havent tried yet?
Fujiz_xb
02-15-2005, 04:23 PM
so it does work correct?
koalaty2
02-17-2005, 04:18 AM
If it fits, would look great. I just covered mine to match new interior. Black/White.
timinaz
02-17-2005, 04:52 AM
I think the overdrive button could be moved, it's only a switch.
squarepants
02-17-2005, 05:11 AM
looks cool but i'll wait for one of you guys to try it out first......... :nails:
Minsk99
02-17-2005, 06:29 AM
I switched automatic ____ knobs on my xb. Raven is right about the button technically being vertical. Also, I moved my old button to a location under the ebrake handle. I also have the button on the new knob hooked up as well. So theoretically the knob could work, its just a question of if it comes with the right adapters to fit our oval bar.
hotbox05
02-17-2005, 06:42 AM
They sell e brake handles you know.
LowProMofo
02-17-2005, 05:21 PM
Here's an auto shift knob:
http://memimage.cardomain.net/member_images/3/web/531000-531999/531755_23_full.jpg
He moved the OD button to the cup holders. I also found this one with a OD button on it.
http://www.obxracingsports.com/interior.cfm?catid=4&subCatID=2&subCat2ID=20
I posted this a while back and found some that may work:
http://www.scionlife.com/forums/viewtopic.php?t=43924&highlight=
Fujiz_xb
02-18-2005, 12:13 AM
well mine didnt work. it didnt fit. so imma return it and i accidentally cut the o/d wires. so i messed up..yes i did..
instead of calling me a dummy any help to figure out which wire is which? they both have polka dots so that doesn't help.
rcstprez
02-18-2005, 01:27 AM
I would guess those wires run either way. All the button is, is a switch that allows current (or a ground) to pass through to close a circuit, and engage or dis-engauge the OD.
MattB
killerxromances
02-18-2005, 01:35 AM
:tap: Well, i've actually tried to swap shift nobs for my automatic and i didn't like how it was set up so i returned it and put the stock one back on. If you want the O.D option, you'll need to re-locate it to a different position. If not, you'll need to either wire it to be left on or left off. With an automatic, if you are doing a lot of interstate driving i would recommend it left on. But its also nice to have that option because you never know when you'll need it...or not need it.
LowProMofo
02-18-2005, 02:52 AM
I agree, I do use mine when I need it. These aren't the fastest cars in the world. I need my OD for passing people most of the time. If I do buy an aftermarket Auto Knob I'll relocate the ODB somewhere.
killerxromances
02-18-2005, 04:04 AM
Yeah, probably the best place to re-locate it would be either right there by the E-brake or cup holders. That way you aren't going all throughout the dashboard just to re-locate. :relief:
Minsk99
02-18-2005, 06:40 AM
Yup. It seems most aftermarket auto knobs don't have the same "action" as the stock. What I did was to splice into the stock OD wires. I hooked one set of wires to the new knobs button and the other I ran under the center cup holder boot (what ever its called) and mounted under the ebrake handle. Both work. I prefer the "action" on the stock button and use it if I have to turn off od quickly. Its actually a convenient location especially if you have an aftermarket armrest because your hand is resting right there.
either way will work.
