Cat-back exhaust suggestions
Old Feb 24, 2010 | 07:04 PM
drivexB's Avatar
Default Cat-back exhaust suggestions
Obviously nothing that sounds like a bee farting in a puddle
Old Feb 24, 2010 | 07:30 PM
burstaneurysm's Avatar
If you want a catback, you're pretty limited... in fact, I think Borla and OBX are the only ones that make a proper catback.
Most other exhausts are axlebacks. If you wanted, you can get the axleback and have piping cut to convert it to catback.
A catback will also need to be welded, axlebacks bolt on.
Old Feb 24, 2010 | 08:42 PM
ajcadoo's Avatar
That actually is not true. TRD makes a cat-back. I have had mine for a year and I love it. Only $200 at sparkstoyota.com
Old Feb 24, 2010 | 09:05 PM
drivexB's Avatar
what about the greddy t-ic or whatever? they say it's a cat-back
welding won't be a problem because I could do it at school
I want to get headers eventually, maybe
I'm not sure where I'm going with my car
I just put an AEM cold air intake into it
Old Feb 24, 2010 | 09:07 PM
You're wrong. That's an axleback exhaust. I had the same one back in the day.
Old Feb 24, 2010 | 09:10 PM
It may say it's a catback, but if you look closely, it will probably say (rear section of catback exhaust)...
There are literally two or three true catback systems available... Borla, OBX, Jardine (which I've only seen available a couple times)
99% of exhausts available for the xB are axleback exhausts, doesn't matter what the descriptions say, that's what they are.
I've had the TRD, Precision Muffler and currently, the Greddy SP2.
Old Feb 24, 2010 | 09:23 PM
OakToddler's Avatar
I have an really nice Doug Thorley Jardine Catback. Got it for under 150 on ebay.
I will see if I can find it for you. It comes with clamps and bolts in case you can't weld it immediately.
See below. Good description. Not a bad price but you may do better on ebay.
http://moesperformance.com/index.php...00533b6341a2b6
Old Feb 24, 2010 | 09:29 PM
drivexB's Avatar
the Borla one is a double tip is it not?
Old Feb 24, 2010 | 09:44 PM
OakToddler's Avatar
Some girl talk on the other site about Jardine...
http://www.clubxb.com/forums/f28/eba...ust-26439.html
Old Feb 24, 2010 | 09:45 PM
ajcadoo's Avatar
Wait what is the difference between the two and why does my invoice call it a catback?
Old Feb 24, 2010 | 09:48 PM
OakToddler's Avatar
axle back is from rear axle to exhaust tip --- it is just muffler
cat back means --- catalytic converter
from the cat all the way to the exhaust tip is cat back
Resonator gets replaced.
Old Feb 24, 2010 | 09:53 PM
OakToddler's Avatar
More info on jardine.....very expensive on their site.....
http://www.dougthorleyheaders.com/pr.../productID/222
Old Feb 24, 2010 | 10:04 PM
OakToddler's Avatar
You will see a little gain from an axleback because of the piping from the header back is still sorta restrictive. Catbacks change the pipe to about 2.5" instead of 1.75" (I think). Allowing for more exhaust flow from the catylatic converter which will reduce back pressure and that gives you more HP.
Old Feb 25, 2010 | 04:18 AM
drivexB's Avatar
there's a parts dealer in my area that marks down performance stuff quite a bit so i could check with them on cost
they may not have it though considering when I went there 4 months ago they didn't even know what scion was
i was going to ask where the welding would need to be done but it would probably be self-explanatory in person eh?
Old Feb 25, 2010 | 11:59 AM
OakToddler's Avatar
I am still clamped and bolted with my Jardine.
Old Feb 25, 2010 | 08:52 PM
Yep.
What he said VVV
There's also header-back... from the header all the way back. Supposedly, the most restrictive part of the exhaust (other than the header) is from the header collector to the cat... replacing that with bigger piping gives even better flow than replacing cat to axle.
Old Feb 25, 2010 | 09:00 PM
OakToddler's Avatar
Is the header back a custom thing?
Or do you buy it off the rack?
Old Feb 25, 2010 | 09:04 PM
Custom.
Old Feb 25, 2010 | 09:29 PM
daneisthegreatest's Avatar
i had header back on my rx-7 and noticed a huge difference, the only problem that i had with that was, i had no back pressure and you really need a little bit of back pressure on rotary engines to keep them running smooth, not sure how the 1nzfe would do.
Old Feb 26, 2010 | 05:10 PM
drivexB's Avatar
I don't think I'd go header back on my car. I don't want to do much custom fab if I don't have to
I'll look in to seeing if they have the jardine exhausts up here, I hope they do
I'd rather bolt it on then mess it up with amateur welding
