Whats the difference...
Old Mar 1, 2010 | 09:00 PM
lucytheshedevil's Avatar
Default Whats the difference...
Between turbo kits for autos and ones for 5spd?
Why do they say a 5spd kit wont fit an auto?
Is the same as like with the supercharger where its just because of the dipstick for the tranny? Or will the tranny itself be in the way?
If I have the auto fit kit from the SC will that solve my prob?
Old Mar 1, 2010 | 09:14 PM
DezodDon's Avatar
Some come with transcoolers.
Old Mar 1, 2010 | 09:18 PM
Yeah but why would that make a 5spd kit not fit an auto?
Old Mar 1, 2010 | 09:19 PM
bdis3's Avatar
^ that,
plus the piping may be a little different to fit around the factory trans cooler lines, and on some kits there are clearance issues with the trans dip stick
Old Mar 1, 2010 | 10:00 PM
Hix's Avatar
Hix
What bdis said. On mine I had to cut the trans dipstick mount and move it.
Old Mar 1, 2010 | 10:18 PM
So thats the only real diff is the dip stick spot?
Old Mar 1, 2010 | 10:39 PM
Hix's Avatar
Hix
Well some kits the whole intercooler piping is off and needs to be changed and on some the downpipe and s-pipe combo are off some its where the turbo is... It all depends on the kit.
You got the SoundPerformance kit right? I'm pretty sure that one fits well, you just will have to push the trans dip out of the way. No cutting or anything.
Old Mar 1, 2010 | 11:15 PM
Yeah i got the SP kit but no one over there knows anything about it lol. They have horrible customer service lol. I hope your right hix
Old Mar 2, 2010 | 09:05 PM
paul_dezod's Avatar
Scionetics
KAD
Sized turbo or specs of it may be different due to the way the auto displaced the load in comparison to a 5 speed.
Old Mar 2, 2010 | 10:00 PM
Hix's Avatar
Hix
they are supra guys, you gotta talk to the right one to get info on the kit. Their pipe set up is alot like the v1 turbonetics but with the shortie intercooler. If it is pushed forward by the dip mount just take a dremmel and cut a tad off the mounting bracket. Is he sending the full kit or just the turbo section? If you have trouble just bring the car to asylum and I'll show you what I did to get mine to fit.
Old Mar 2, 2010 | 11:07 PM
mrhat's Avatar
so when buying a kit for my auto I need to buy an auto kit and not a used manual kit? I was looking at the 06 greddy kit for my tc or that upgraded zpi kit.
Old Mar 2, 2010 | 11:09 PM
jsmillie07's Avatar
It would definitely be easier if you got a kit that was made for the auto. If you got one for a 5spd you might have to modify some parts.
Old Mar 2, 2010 | 11:58 PM
deathbyc4's Avatar
shoulda asked me
Old Mar 3, 2010 | 01:37 AM
Well the SP kit fit just need a tune does anyone know the relay fix for autos for the FIC?
Old Mar 3, 2010 | 01:59 AM
Hix's Avatar
Hix
PM Chris he just did one a few days ago... He is Crush(and some numbers lol), he is also on the Scikotics forums.
Old Mar 3, 2010 | 02:02 AM
crush02342002's Avatar
its fairly streight forward...give me a sec and let me see if i can find some pics..
Old Mar 3, 2010 | 02:03 AM
Thanks I PMed him.
oh and thanks crush didnt see ur post lol
Old Mar 3, 2010 | 02:09 AM
here is a link youll need http://www.dezod.com/files/ECU%20pinouts----.pdf
you want to take the wire e4-8 (aka EFI RELAY) and cut it (try to get as much slack as you can, its kinda hard to do and be careful not to damage the wire), take one end to the common pin for the switch on the relay and the other end to the normally closed pin.
here is a pic of a standard automotive relay for example
pin 85 and 86 are the coil of this relay so one pin will go to a ground (doesnt matter, nearest bolt or screw will do as long as its a good ground) and the other pin needs to go to a switched + that will come on with the key in the on position.
pin 87a will not be used
pin 87 and 30 will go to the efi relay (e4-8
any questions?
Old Mar 3, 2010 | 02:16 AM
maybe i should add this to the aem fic set up..but no one sees it anymore and wont know were to look...lulz
