Will this work? Trailer wiring kit for Scion xA?
Old Mar 11, 2010 | 09:04 PM
dtpmike's Avatar
Default Will this work? Trailer wiring kit for Scion xA?
I don't know a lot about trailer wiring. I have a 2005 scion xa and a light HF trailer. From what I hear I need a converter for the trailer lights to work correctly.
http://cgi.ebay.com/ebaymotors/04-07...Q5fAccessories
There are no trailer wiring kits for the Scion xA, but I figured since this is for the xB it would probably work for my 2005 xA. Do you think it will work?
Old Mar 11, 2010 | 09:12 PM
dtpmike's Avatar
really I just want the cheapest way to connect it. I don't need T-fittings.
Would this work?
http://cgi.ebay.com/ebaymotors/Tail-...ht_3000wt_1165
or even cheaper:
http://cgi.ebay.com/ebaymotors/Tail-...Q5fAccessories
Old Mar 30, 2010 | 10:15 PM
mcbrew's Avatar
Just go to Autozone, Pep Boys, or whatever auto parts store they have where you live and pick up a Hopkins (aka Hoppy) converter. The one I use (in three different cars) is their model number 46255 "Power Taillight Converter". The "Power" part means that it uses power directly from your car's battery to run the trailer's lights instead of taking power from your car's tail light wiring. That makes your trailer lights brighter and eliminates the risk of blowing a fuse or otherwise damaging your tail light electrical system.
Everything you need (other than tools) comes in the package... including scotch-locks to tap into the wiring, the fused wire to run to your battery, and even the trailer light pig-tail that you hang out of the trunk to hook to your trailer.
Old Mar 30, 2010 | 10:20 PM
mcbrew's Avatar
There is another brand called TowReady. eTrailer.com sells that one, and they have a video on their website showing how to install it. Search their site for item 119176KIT or just 119176 (you want the kit, but they have different videos for each, so that might be helpful to you).
Old Mar 31, 2010 | 01:18 AM
dtpmike's Avatar
I ended up buying a converter (non-powered) from walmart for $15. Works great. I know if I ever use a trailer with more lights I will need a powered one, but the non-powered version works fine for my trailer.
Old Sep 16, 2010 | 12:42 AM
Kessog's Avatar
I know this is an old thread but I just wired my 2006 xA for a small utility trailer. I got the Curt hitch (4 bolt install with some jimmying around the exhaust) and the Curt xB powered converter (p/n 56030). A five minute rewiring of the plugs on the xB converter is needed to match the xA tail light pinout but it works like a charm and snaps right in. I mounted the converter by the right tail light and grounded it on the mount stud. A bit more work but a totally clean install and no damage to the car wires.
Attached Thumbnails Will this work?  Trailer wiring kit for Scion xA?-trailer-hitched-b.jpg
Old Sep 16, 2010 | 02:39 AM
mcbrew's Avatar
Nice little trailer... I prefer this setup, though:
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
minter66
Dec 15, 2014 01:45 PM
lunchbx05
Dec 11, 2014 06:13 PM
mdhyre
Dec 7, 2014 12:52 AM
deathcabforme
Oct 16, 2003 04:02 AM
