Need some help with parts
Old Mar 14, 2010 | 11:56 PM
oreoremix42's Avatar
Default Need some help with parts
Ok I recently tore my whole interior out of the xb2, and in doing so some things were a PITA and didn't come out properly.
The first one is the dome light directly above your head. The one that turns on when you open the door. The one clip broke and it doesn't clip in now
The second is the sunvisor clip. Not the sunvisor itself but what the sunvisor clips into. This piece:
Then the 3rd piece I need is the interior door panel. The spring inside of my door handle stripped out of place and now won't work. Not sure how this one happened. I took teh door panel off and when I put it back on wouldn't work. Most likely will need the whole assembly.
Old Mar 15, 2010 | 12:01 AM
buickid's Avatar
Are you looking for a source of new parts or what?
Dealership is going to be expensive, I'd suggest checking out a couple junkyards first.
Old Mar 15, 2010 | 12:12 AM
Either source, or links to the exact parts. The places I looked I had a hard time finding what I needed.
Old Mar 15, 2010 | 01:09 AM
TrevorS's Avatar
First check to make sure glue can't solve any of the problems. From what I'd been told, I understood the dome light pulled straight out with just a little prying. Well, that turned out to be totally falacious and so I ended up having to reinforce and glue the back end of one of the retracting clips. Fortunately, it worked out fine. Good luck!
Old Mar 15, 2010 | 05:04 AM
buickid's Avatar
I'm almost willing to bet you could find the light and visor clip in any other similar Toyota. Go to the junkyard and look in the Toyotas. I'd put my money on some Corollas and Matrixs (Matrices?) of similar year. Say... 2005+
Other car companies have a bunch of parts that they tend to use throughout their model lines, I don't see why Toyota wouldn't do something similar.
Old Mar 15, 2010 | 04:02 PM
Just went to the dealer for everything. The first 2 were like 23 bucks and the door handle I found online cheap
Old Mar 15, 2010 | 04:37 PM
Greg S's Avatar
For the door handle the spring will go right back in to place. There is nothing to strip out, I've removed and completely disassembled mine 4-5 times for each door and they go back together everytime. If you take a look at one of the other handles you'll be able to see exactly how they go together.
Marganne
Apr 3, 2015 06:52 PM
Ramroids55
Jan 16, 2015 02:42 PM
TheTripleC
Jan 4, 2015 06:46 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
