Radio Install Help!
Old Mar 21, 2010 | 02:54 PM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
Default Radio Install Help!
Everything works on my radio (dvd, ipod, cd...) except my radio. Can't get a good signal. I was told there's a power antenna wire or something. What wires do I have to hook up to get it? Only wire I see free back there is ONE blue one, no other ones to connect it to. Do I have to splice it in somewhere's?
Old Mar 21, 2010 | 08:35 PM
Slody4Futbol's Avatar
Did you use a vehicle specific wiring harness to plug into the stock harness? If so there should be a blue wire in it. It may/may not be labeled power antenna. Hook it to the blue or blue/white wire in your radios harness.
Old Mar 21, 2010 | 09:21 PM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
Yes, I used all the vehicle specific stuff. Where do I hook my amp remote wire up to then? That's where that blue wire is going now.
Old Mar 21, 2010 | 09:39 PM
the remote wire from the amp goes to the blue/white on the back of the headunit.. if it does not have a blue/white it goes to blue
Old Mar 22, 2010 | 02:10 AM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
So those 3 wires need to hook up together?
The only blue wires I have back there are these...
Blue remote wire that comes from my amp
Blue wire from the wire harness
Blue/white wire from radio.
Old Mar 28, 2010 | 04:48 PM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
Bump, anyone?
Old Mar 28, 2010 | 06:01 PM
XBinRochester's Avatar
I would assume yes, all three should be connected together, so the Antenna and Power Amp both power up when the Radio is turned on.
Old Mar 28, 2010 | 08:35 PM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
That's how it is now, and still nothing.
Old Mar 28, 2010 | 09:11 PM
as long as all your blue & blue/white wires are hooked up.. then you should be fine.. verify that your antenna wire is properly plugged into your radio.. and last..
what radio is it? brand/model?
Old Mar 29, 2010 | 12:41 AM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
Pioneer P4100DVD
Yeah, all the blue wires are hooked up, and antenna plug is in all the way. I had this radio, the exact one in my 1st 2nd gen before I traded it in and it worked perfectly. When I swapped it to this car I can't get a reception.
Old Mar 29, 2010 | 01:18 AM
no clue.. meter the wire to make sure it is sending out 12v to the antenna line.. and make sure your antenna is still on your vehicle lol
Old Mar 29, 2010 | 04:12 AM
Audiomechanic's Avatar
DO you have a power antenna on the car? You should only have to use the blue or blue/white to turn on an amp or signal a motorized antenna.
What kind of radio was in the car before? Was the AM/FM working on it?
Old Mar 29, 2010 | 06:10 AM
or an amplified antenna.. and i believe the xb's antenna is amplified
Old Mar 29, 2010 | 03:51 PM
Yes, my bad. I left out amplified antennas, which are more typically used in vehicles that have window/glass mounted antennas or low profile/shark fin antennas.
I have only had my xB for 2 weeks, and I do believe that the antenna is amplified.
Some radios will have 2 wires, a blue and a blue w/ white stripe. Others just 1 wire that is a Remote Turn-on, typically Blue w/ White stripe.
Blue = Antenna remote (only powers on when the AM/FM tuner is in use)
Blue w/ White stripe = Amp remote (this wire powers up anytime the head unit is in use)
As far as the reception issue, since the radio was in a previous xB did you redo the wiring harness or keep the old wiring and just plug it in?
Without metering the blue / blue w/ white wire to see if it is reading 12 volts positive when the radio is on, I would guess and say that either the tuner in the radio has gone bad (rare, but it does happen) or that the remote turn-on is no longer producing 12 volts + (a little more common) or that the antenna on the car is disconnected, damaged, or bad.
Old Mar 29, 2010 | 10:12 PM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
Had the stock radio in it that was working perfectly when I took it out.
Removed the radio from my old car, harness and all, and just plugged everything right back into this one and nothing.
Old Mar 31, 2010 | 02:37 AM
AndreyCo's Avatar
I followed the color codes from the Metra harness that I got and the color codes from my Pioneer AVIC-F700BT. Didn't have any problems with the radio.
Old Mar 31, 2010 | 05:25 PM
did you test the power antenna wire for 12v? and check the vehicle side of the stock harness to verify there's not a problem in the connector?
Old Mar 31, 2010 | 09:21 PM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
No. I don't have anything on hand to do that with, and just been busy the last few days.
Old Apr 1, 2010 | 05:27 PM
scvscions's Avatar
its the orange wire on connector 1 thats the power antenna for the xB2(same connector that the power,ground, acc, front speakers are on). Connect your blue/white wire to it and it should work, if not check the fuses to make sure that they're good. And make sure the unit is sending power off that wire.
Old Apr 1, 2010 | 07:18 PM
and to the OP.. when he says orange.. he means on the vehicle side of the harness.. not the orange for the aftermarket harness you have ;) then you'd be hooking your remote wire to illumination..
just look on the vehicle side of the harness for an orange wire.. follow it to the side where you installed the aftermarket harness.. see if there is a wire pinned to that slot.. if so.. hook your blue or blue/white to it.. if there is not a wire there.. then just strip back some of the insulation.. and connect your wire to the vehicle side.. no need to cut the wire.. just strip back insulation
