HELP!!Wanna add audio components to OEM CD deck
Old Feb 17, 2005 | 08:03 PM
tinnerman88's Avatar
Default HELP!!Wanna add audio components to OEM CD deck
I have an '05 xB with the base model single-CD Head Unit that I want to connect an Eclipse amplifier (model #3242),(2) Eclipse 1" tweeters,(2) JL Audio 6" mid-ranges and a 12" Alpine sub-woofer to..........What I don't have is car audio experience.I've done wiring in my house and I'm very mechanical so I figure I can tackle it ......Will someone PLEASE walk me step-by-step thru an install or at least lay it out for me? I have all this stuff beggin to go!!
Old Feb 17, 2005 | 08:36 PM
Max2k's Avatar
This isn't what you want to hear, but you really should probably throw down for a proper head unit, your music will sound much better.
Old Feb 17, 2005 | 10:00 PM
ChefRaekwon's Avatar
First you will need to purchase a Line Output Converter which you will connect to the factory Pioneer CD Player so you can run an amplifier off of it. It will turn speaker leads into RCA Jacks. I don't own an XB so I can't tell you how to install the speakers or where to put ur amp but you will need that Line Out Converter before you start anything. Otherwise buy a new CD Player.
Better off using a aftermarket cd player you will get alot better sound out of that amp and components.
Old Feb 17, 2005 | 10:53 PM
Scievolution85's Avatar
if you were to purchase an aftermarket headunit, would that void any warranties?
Old Feb 17, 2005 | 11:46 PM
TheScionicMan's Avatar
Well, they won't replace it if it fails, cuz the part they cover by warranty is sitting on your shelf or something
Just get a replacement kit from Metra or the like that uses plug in adaptors so you don't have to touch the factory wiring...
Old Feb 18, 2005 | 01:20 AM
Max2k's Avatar
Scionic Man is right. I installed my head unit in about 5 minutes with my metra harnesses, it was all plug and play except for the amp shutoff wire.
As for warantees, like the scionic man said: they won't cover it if you blow out your speakers, but if your wheel falls off or something you'll be fine.
Old Feb 18, 2005 | 03:05 AM
ScionRI's Avatar
sIcKsCiOnS
i have a question: How do you intend to cross over these 1" eclipse tweets and 6 inch JL mids?
Please explain this to me.
killahXB2
Mar 27, 2015 10:45 AM
toyotaisme
Jan 10, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
cwong1001
Dec 3, 2014 03:30 AM
carid
Nov 21, 2014 11:00 AM
