View Full Version : Help! Monroe rear shock install, pic included!
glhboy
03-25-2010, 10:11 PM
So I bought the Monroe 5601's, for my 06 xb, stock replacement, but I can't figure the hardware out on them. From all the installation threads I've seen, it shows that I remove the plastic boot from the old shock and put on the new one, but these 5601's already have a boot on them and come with rubber bump stops and gold washers. I can't remove the boot from the new one since it appears to be welded on. I have attached a picture.
The one on the right is the stock shock with boot removed, left is new shock.
Anyone???
I have one shock still off the car and need to finish this tonight.
bbszero
03-25-2010, 11:30 PM
put the new one in, then install the rubber piece, then the cup washer, then the bolt.
glhboy
03-25-2010, 11:37 PM
So I don't use any old hardware/rubber stops?
When I put the new shock in(I took it back out)
I put a cup washer on the new shock, rubber bushing, then put the shock in the car, once the threads were through the hole at the top, I put a rubber bushing and another cup washer, then the nut, but when tightening the nut, it kept turning the dust boot on the shock itself.
I took the new shock back off and put the old one back on for now to make sure I was doing this right.
All the pictures I see you just use the old dust boot from the stock shock on the new ones.
tipc4life
03-26-2010, 01:57 AM
cazn i ask y did you go with them just a ?
bB2NER
03-28-2010, 11:16 PM
If the new ones have the upper shroud welded on it must already have a bump stop so go ahead and install them. Be sure to use the right washers and rubber bushings tho.
Might I ask why you didn't do the fronts also? It really does improve the ride.
burstaneurysm
03-28-2010, 11:35 PM
Just pop the rubber bushing on top and put em in. You reuse the hardware inside the car, rubber and washer.
Those have integrated dust shields, no need to swap em.
Babe
06-15-2010, 12:55 AM
I have the same problem.
you get 2 large washers and 2 rubber things and one nut
one side of the rubber thingy is larger than the other side, which end is up or visa versa...
the dust cover is on the new shock and you can't remove it.
anyone really know this one
whatevertrick
08-19-2010, 04:29 AM
just got done doing this myself. I put new metal washer on then the new rubber washer with the smaller end to the body of the box. then lowered the box down and guided the smaller part of the rubber into the center of the hole. the smaller part of the rubber washer is almost the same size the the hole on the body of the box. then i put the rubber washer on with the smaller part to the body of the box, metal washer and the nut. i had to hold the metal dust boot to tighten down the nut until i could fit a 1/4" wrench to hold the piston shaft from turning. hope this helps
biancoxb
12-01-2010, 11:52 PM
whatevertrick, is it normal to hear a clanking noise coming from the rear shocks when going over the harsher bumps? I installed them the same way, but I think the first bottom metal washer may be clanking on the shock itself. I was debating if I should remove it, but I am not too sure if it is creating the sound or could be something else. I checked all bolts and they are all torqued tight.
