17x8 et 37 or 35 in the rear? spacers? Jasper Ash and Tom11x need help
Old Mar 27, 2010 | 09:26 AM
Tom11x's Avatar
Default 17x8 et 37 or 35 in the rear? spacers? Jasper Ash and Tom11x need help
what spacer should i get?
im looking 10mm or 15mm or 20mm? any suggestion. im on coilovers. dont want to fender roll. going to slam with 225/45/17
H&R or ichiba V1 or V2
17x7.5 et 30 (Front)
17x8 et 37 (Rear)
Thanks chrischoi. (He told me i needed spacer or it will look funny because the front will look flush and the rear will be sunken in)
need your help guys.
Old Mar 28, 2010 | 06:13 PM
Jasper Ash's Avatar
I don't know much about flushness just yet - I'm still learning. But I'm pretty sure you'll need to roll fenders or add neg. camber if you add spacers. Especially if you're slammed. Even if you use thinner tires you still might need to make adjustments to run spacers. I'm curious about this as well as I am going to be running a somewhat similar set-up (17x8 et 35). Can someone clarify?
Last edited by Jasper Ash; Mar 29, 2010 at 04:34 PM. Reason: Sometimes I cannot spell.
Old Mar 28, 2010 | 07:36 PM
Tom11x's Avatar
title change jasper ash
Old Mar 28, 2010 | 08:28 PM
NYNCTC's Avatar
ok, my professors are +37 up front (17x 8 and I have about a degree of camber and I only rub on large dips (I have my fender lining in too). my rears are +24 and I have 2.5 degrees of camber and no rub (stock fenders).
Old Mar 28, 2010 | 10:20 PM
07-5spd-SprWht-tC's Avatar
in front im running 19x8 +35 with a 10mm spacer (+25 now) and a slightly stretched 215/35. no camber up front just removed fender liners and I have no rubbing issues also maxed out on racelands. rears were the same set up but with a 25mm spacer (+10 now) with rolled fenders and some mad trimming work with a dremel, running approx 2degrees of camber and only rub on good sized dips.
Old Mar 28, 2010 | 10:25 PM
dude take your fender liners out you really shouldnt be rubbing in front with your setup i was running +35 for the about 2years lowered on stechs and 19s and never rubbed once with liners still in
Old Mar 28, 2010 | 10:28 PM
whats the offset up front? +37 or +35 isn't flush. id throw a 10mm up front and remove fender liner. ok maybe a 5mm because your sidewall is pretty meaty. lol
Old Mar 28, 2010 | 11:00 PM
Tom11x's Avatar
the front is 17x7.5 et 30 and the rear is 17x8 et 37
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
scionlife
371
Jun 2, 2015 11:00 PM
stayintrucha
Apr 27, 2015 07:55 PM
CAtC12
Dec 23, 2014 04:44 PM
scionara
38
Feb 25, 2004 04:52 AM
