Service at 54k (Switching to Synthetic? BG44K?)
i have ~54k on my tC and it has been more than 3900 miles since i last got it serviced. i have been going to the dealership so far but have now decided to get all the parts myself and go to my local mechanic instead.
-i recently had all 4 brake pads/rotors replaced so that should be good.
-Engine Oil/BG44K®:
i have been using conventional oil so far but am planning to switch to synthetic (Mobil 1 Extended Performance 5W-30 Motor Oil). i am assuming it is not too late to switch ??? :--) Before getting the oil change done, i am going to use BG44K as per the following directions:
Directions – How to Use BG44K®?
Add a full can of BG44K® to the fuel tank using the pouring funnel provided (its best to do this at a filling station.) Then fill the tank full with petrol immediately afterwards.
Drive your vehicle normally but try to make the tank last for at least a week or 2-3 weeks if possible. Short journeys will help ensure 44K has the chance to clean the fuel system thoroughly. When your vehicle is left with approximately ¼ tank of fuel remaining, fill up again. This will give you a very potent dose for ¾ of a tank and a less potent dose (but still strong when compared to other cleaners) for another full tank of fuel.
is there anything else i need to do ?
-Use OEM Oil Filter and Drain Plug Gasket.
-Replace Tranny Oil: Amsoil-Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 API GL-4 (MTG)
-Replace spark plugs: NGK part no 4589 (Laser Iridium). i should be able to change them myself.
-Replace air filter with OEM
-Drain and fill coolant with OEM. i am thinking of having the shop do this.
let me know if you guys have any comments or suggestions. thx.
-Engine Oil/BG44K®:
adding the following to the list:
-clean MAF sensor
-change PCV valve (http://trdsparks.com/displayparts.ph...&parts_id=3500)
-clean MAF sensor
If you are going to run Mobil 1 extended performance, max sure you get your money's out of it. You could easily get 10k miles out of that oil.
The plugs are good for 100k miles, seems a little early to swap them out imo.
Damn, wish I was still in the Chicago area, I'd definitely lend you a hand and hook you up with Amsoil at dealer pricing.
I personally wouldn't pay a shop to do anything. No one does it better than yourself. Do it yourself and have the satisfaction of it.
How does the coolant look? I usually don't change the coolant until close to 100k miles.
How is the brake fluid? If you can swing it, go with synthetic brake fluid. I only have 23k miles on my tC so I still have the factory brake fluid in there. I'll change it over to synthetic when I get the motivation to put some speed bleeders and stainless brake lines in there. But the brake fluid is still too clean for me to think about changing it.
$40 for those plugs, why not?
gedster314
14
Nov 17, 2018 02:56 PM
rvascion
Scion xB 2nd-Gen Wheel & Tire
Aug 16, 2015 02:26 AM
