H tech camber questions
Old Mar 31, 2010 | 06:17 PM
Mod-Bug's Avatar
Default H tech camber questions
Anyone with Htechs out there, are you running camber bolts with this set up? I know you can get away without them when running trd's but since H techs are a little bit lower I am wondering if they are needed at this point.
Hopefully picked up a set of Htech from a member on here and just want to go ahead and order bolts if I need them so I can do the install when it all arrives.
Old Mar 31, 2010 | 06:19 PM
ack154's Avatar
Should not be necessary. Just get an alignment afterwards.
Old Mar 31, 2010 | 06:21 PM
Mod-Bug's Avatar
So you think the car can adjust out that much camber? I will accept -1 degree actually but was just curious if it would end up being more than that with these springs.
But since they are used, I should be able to do an alignment right away as they should pretty much be settled as soon as they are installed I would think.
Old Mar 31, 2010 | 06:23 PM
ack154's Avatar
You'll be fine. I've been on Hotchkis springs without camber adjustment and they're quite a bit lower than H Techs. Seriously, you should be fine.
If a shop tells you otherwise when aligning, go to another shop. MANY people are on them without any camber correction.
Old Mar 31, 2010 | 06:25 PM
Mod-Bug's Avatar
OUtstanding. I trust my shop though as they are all my old Suby buddies. Can't frickn weight to lower this thing. I've been riding on stock suspension for over two weeks and it is killing me.
Old Mar 31, 2010 | 08:10 PM
xdejablu3x's Avatar
im running negative camber in the rear on TRD shocks and H-techs. did my alignment and everything and its still -0.1 on the left side.
Old Mar 31, 2010 | 10:47 PM
DJ08tC's Avatar
-0.1? that is absolutely nothing, lol
Old Mar 31, 2010 | 11:17 PM
pinoyFMtC's Avatar
When I used to have H-Techs, they got the alignment completely within OEM spec without any additional parts.
Old Mar 31, 2010 | 11:42 PM
my06tc's Avatar
im on H techs also and got and alignment a few weeks after, and got it all within oem spec also
Old Apr 1, 2010 | 01:05 AM
xdejablu3x's Avatar
lol yeah i know. im just posting it up to help the OP out...but yeah from what ive gone through i really dont need any camber kits.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
