Could use some help!!
Old Apr 4, 2010 | 05:51 AM
BigPinoyTC's Avatar
Default Could use some help!!
Well I'm not sure what happened yet because I haven't taken the turbo out yet to see if there is any visible damage without actually taking the turbo apart.
I've been having problems with my car suddenly losing power for a second or so (also feels like loses all boost). It doesnt happen all the time and last night i got on the throttle a little and after i let off i heard a noise from the turbo. It sounds almost like when i was a kid and would put a playing card in the spokes of your bike to make it sound cool. lol....i had to drive it home and it still holds boost for the most part. I plan on taking it off within the next day or so to inspect it.
I just bought the turbo through sound performance and its a precision turbo. Its only been on since october so i still have the year warranty so hopefully what ever is wrong they will cover it.
Thanks
Old Apr 4, 2010 | 06:43 AM
STlTCHES's Avatar
Weird question is your BOV working?
How much boost?
I ask about the BOV and boost b/c too much pressure without a proper blow off could cause the blade in the turbo resistance and wobble. (only thing i can think of)
Old Apr 4, 2010 | 05:18 PM
BigPinoyTC's Avatar
My BOV does still work. I have a SSQV. When i get it off im gonna check for any damage and if there is any play in the shaft. i hope not . Has anyone ever had similiar problems with a precision turbo and had to send it back? I want to know if they will cover it or at least if its going to cost me some good money to get it fixed.
Old Apr 4, 2010 | 05:21 PM
cburglb34's Avatar
i wanna say one of your wheels is making contact, because when one of my turbos made contact...the car would boost then not boost and then after 5 hours the wheel broke off lol, anyways idk cuz contact usually sound slike a supercharger
Old Apr 6, 2010 | 04:07 AM
BigPinoyTC's Avatar
I know the turbo issue will have to be checked and fixed through precision but to rule out other issues with why my car just loses boost all of a sudden how can i check to make sure my BOV is operating correctly. I have noticed that it has been sounding a lot different when it goes off almost as if i was running more boost because it has been a lot louder and i havent changed my boost.
Old Apr 6, 2010 | 04:22 AM
crush02342002's Avatar
agree
Old Apr 6, 2010 | 05:07 AM
BigPinoyTC's Avatar
im thinking just from your discription that may be the problem bkuz it does boost and then lose boost right away and right now it does sound like a supercharger (whine like noise)
Old Apr 6, 2010 | 05:26 AM
if a turbo rebuild is in order i can help you out in that...a way to check is to take the turbo intake pipe off and wiggle the shaft, if it seems to move alot or if you pull up and try to turn the shaft and wont turn or makes a scratching noise then it looks like a rebuilt turbo is in the future.
sig that mike...lmao
Old Apr 6, 2010 | 06:44 PM
deathbyc4's Avatar
i had the same problem, turbo has gone bad. this is the fifth time mine has died.
Old Apr 6, 2010 | 06:50 PM
deathbyc4's Avatar
btw, good luck with the rebuild, it took Precision four months to rebuild mine last year, they have horrible customer service, you can ask SP about that.
Old Apr 6, 2010 | 09:44 PM
Syldrin's Avatar
if you're turbo checks out it could be your wastegate.
Old Apr 6, 2010 | 10:37 PM
deathbyc4's Avatar
and check the BOV too, i switched or the the synchronic and it made a world of difference, the hks didnt work right, both the old version and new version.
Old Apr 11, 2010 | 12:23 AM
BigPinoyTC's Avatar
ok so precision called me and the turbo checked out to be fine. So now to figure out what that noise is coming from and what caused it. So i guess i need to check the BOV and wastegate. What do i look for when testing the BOV and wastegate? How do i check them.
Old Apr 11, 2010 | 12:36 AM
maybe bov not quit holding boost, if its adjustable try tightening to a stiffer setting. boost leak test may help to find out if the bov isnt holding.
Old Apr 11, 2010 | 12:52 AM
ElevationTC's Avatar
Do you have the hks BOV? These bov's are known to leak and cause issues.
Have not read the entire post. But try swapping bov's with a friend.
Also As mentioned check turbo for shaft play! And Boost leak test!
Old Apr 11, 2010 | 05:26 AM
cburglb34's Avatar
hmm really mike? they are pull type so when under boos tthe boost holds it closed.....
Old Apr 12, 2010 | 04:45 AM
BigPinoyTC's Avatar
I do have the HKS SSQV and i have been told before about the problems with the BOV. I havent noticed a leak in BOV but ill try swapping it out with another and see what happens. I might just end up buying a new one.
Old Apr 12, 2010 | 07:07 AM
deathbyc4's Avatar
im tellin ya, switch to synapse.
Old Apr 13, 2010 | 01:30 AM
BigPinoyTC's Avatar
Ok fine! Sell me yours!!!
Old Apr 13, 2010 | 08:13 AM
deathbyc4's Avatar
I'm still in a debate of selling or keeping my kit, i dunno. As much of a PITA it is to work on this car, i am also obligated to boost it since i do have a built motor now
