Injen Cold Air Intake w/ heatsheild and engine cover painted.
Installed my Injen Cold Air intake Friday. Decided to Paint the Heat sheild and engine cover to match the black tubing on the cold air intake. I think it turned out pretty good!
I was trying to see if I could pull off a Gloss effect with High Temp paint but looks like it didn't do to well. =( Used Spray cans...
3 coats of 2000 Degree Primer, 3 coats 500 Degree Black Gloss (failed), 3 coats 2000 degree clear coat. Was gonna see if I could get away with the 500 degree black gloss but the heat from the header said F u lol. Looks like I gotta use a 2000 Degree Flat black instead.
its not unless you cut out your actual metal bumper, the tow hook screws directly into the bumper itself, the intake filter will be under the splash guard and behind the bumper, directly behind the plastic corner vents, which you can remove to increase air plow but you need to be running a foam bypass valve to prevent hydrolock, that should avoid some of the threadjack, engine bay looks good BTW
steeze69
May 24, 2021 02:57 AM
carid
Feb 10, 2019 10:46 PM
Threequalseven
Aug 26, 2015 04:24 PM
