View Full Version : ZPI Racing Stage 1 Head Package for the Scion tC
tCtunerZ
02-19-2005, 12:42 AM
Zero Point Industries a leader in the Subaru arena has now taken what they have learned at building Subaru and applied it to the tC. With many new products to come from Zero Point and the ZPI Racing product line in the next few months.
This is their Stage 1 head package currently offered for the tC. The stock head was found to be very restrictive the Stage 1 head flows 38% better on our flow bench than the stock head. This is with retaining stock valves you can expect an even more significant gain as Stage 2 and 3 become available later in the spring.
click the link to read the rest of the article;
http://www.tctunerz.com/article-zone/engine/zpi-racing-stage-1-head-package-for-the-scion-tc.html
http://www.tctunerz.com/images/stories/albums/sciontc-engine-zpi/scion_tc_head_package_1.jpg
LucidBD
02-19-2005, 01:28 AM
@ $550 with 30HP wheel gain...could this be the best source for HP for the money yet?
jrv2000
02-19-2005, 02:53 AM
"The intake and exhaust are port matched the whole head is ported and polished the valves are reworked to our confidential specs. The greatest thing about this mod is that the dealership will never know if you have to take it in for a warranty issue. "
Im not really familiar with these terms, if you could explain, or link me to a page that could explain port matching, and ported/polished heads, that would be great. Also, how could it be that the dealership wouldn't know this has been done. If a machanic has seen hundreds of these engines(b/c it is the same engine shared with the camry), dont you think he'll pick up these changes that have been done?
TheKnown
02-19-2005, 03:46 AM
sounds like a bang for the buck, however i would like to see some dynos
Joe_Dezod
02-19-2005, 03:55 AM
Once I see a dyno I'll definately be interested.
This would be a great mod for those with a S/C through the dealer, and want the most HP possible.
tckurt
02-19-2005, 05:02 AM
Wow 30 HP for stage 1 wonder how much Stage 2 or 3 will have? even if stage three is only 50hp its probably not gonna be more than 1200 which is a lot cheaper than the S/C but having both oooh the possibilities only if I could afford both :pray:
KYBoy
02-19-2005, 05:54 AM
ZPI is right down the street from me, they have a really nice shop, very clean and do good work.
i guess i will have to go over there and check it out
Joe_Dezod
02-19-2005, 06:11 AM
It says "up to 30whp"... Do not expect that much just from bolting it on. You will have to get some fuel adjustments made to compensate for the added airflow. Headers that are port matched to the exhaust ports on the head will also be ideal in getting out as much air as possible, with minimal turbulance. I'd also expect 30whp only under boosted conditions.
Who knows though, but either way, I have thought of the tC needed much better top end, and this mod should help. We shall see once the dyno's are released.
niguels
02-19-2005, 06:13 AM
I want to see a dyno too. How does Torque and HP do behave across the powerband compared to the stock unit?
Factual data will be appreciated
acasanova
02-19-2005, 06:23 AM
Even if its 20hp its still worth it .But i need to see the numbers also i would hope that it wouldnt screw low end .
tckurt
02-19-2005, 03:13 PM
Will a aftermarket header or the supercharger still work with bigger ports?
tCtunerZ
02-19-2005, 05:24 PM
Dyno numbers will be posted on our site next week including ordering information pertaining to the core exchange.
aarontrini85
02-19-2005, 08:41 PM
This will go great with my nitrous kit, k&n intake, and injen exhaust. What is involved in the install? Is it something i should be able to do in my garage at home?
kutsuju_dj
02-19-2005, 09:45 PM
you will be the first one to blow up your engine :rofl: na for real though..... if your running nos and considering this, you should seriously consider having it profesionally done........
tCtunerZ
02-19-2005, 10:11 PM
Next week we will have updated ordering and installation information on our site with dyno results. It is highly recommended to have a pro install due to major labor involved with install including removal of oil pan, engine mount and other components.
LucidBD
02-20-2005, 12:15 AM
Nawz!!! d00d...dont screw up the new engine...get boosted
Hippy
02-20-2005, 12:47 AM
During the manufacturing process of the clylinder head casting rough surfaces exist thoughout the heads. The head is machined so that valve guides and valves seat correctly.
Exhaust Port matching means removing extra material from the cylinder head were the exhaust manifold bolts to the head. Intake Port matching means removing extra material from the cylinder head were the intake manifold bolts to the head. Normally material at these openings would be removed to allow a smoother entrance of air and exhaust gasses in and out of the head.
Porting & polishing is a continuing of portmatching to the head from the opening of the port to the valve the entire port is ground smooth and polished (look at the picture) that allows even more free flow of gasses.
Clyinder head work is for a machinist that really knows what he's doing. Hours and hours of R&D to find the right balance of how much Air the engine can consume and how fast it can get the air out.
A dyno sheet will help show how the modifications will help or hurt the performance of your engine.
Modifications are designed for a specific RPM range. If this machine work is for High RPM it will more than likely hurt low RPM torque and horsepower driveability and fuel economy. Before considering any engine mod you have to be honest with yourself is that the engine RPM that I normally run my motor at.
For me I'd like to find some mods that would help out below the 4500 RPM most of my driving is just cruising back and forth to work.
finding 30 or 40 horse at 7000 RPM might just turn my 33MPG slug into a 20MPG slower slug.
Hippy
02-20-2005, 12:54 AM
If you take it into the dealer with and engine problem and they have to open it up to see what happened to cause your engine problem the mechanic WILL know that that is not a stock head. Warranty VOID.
BTW I metioned 33MPG in previous post I was thinking of my XB. My Wife's TC is getting 29 but you understand my point.
Vince
tCtunerZ
02-20-2005, 12:58 AM
Very valid points, all text is from manufacture and any questions posted on this post will be answered in detail next week.
chris0
02-20-2005, 01:26 AM
mmm...why did tctunerz just quote Hippy?
chris
tCtunerZ
02-20-2005, 02:34 AM
I've been posting from my Sidekick 2 and tried to quote the post regarding the different types of porting however I don't think it worked right.
I can't wait till the HP iPAQ gets off backorder!
jrv2000
02-20-2005, 04:20 AM
Thanks for the info hippy, i was a little bit weiry when they said that the dealer wouldn't know the engine had been modified. I guess what they meant was they wouldn't know it if they just looked at it, without taking it apart.
Joe_Dezod
02-20-2005, 05:38 AM
This is definately something you don't want to do yourself, especially if you have to ask if you can or not. No offense, this is just one of the most vital parts of the motor and it has to be perfect. Things as small as a specific pattern and routine for torque-ing down the head steads have to be perfect or kiss the motor goodbye. A warped head will blow HG's left and right, and you will have fun finding someone to re-machine it for you.
I'm not trying to scare anyone, a head is a great mod, just get it professionally done and reep the benefits.
aarontrini85
02-20-2005, 03:50 PM
thank you for that good answer ill check and see how mutch my local shop will charge to instaall
JdMBboFSD
02-20-2005, 04:12 PM
does ZPI have one for the XB?
bambams247
02-20-2005, 04:24 PM
Core charge and install pics please? and a dyno on a stock tC with no mods.
TurboCustomz
02-21-2005, 06:05 PM
I just want to thank everyone for the interest in our products. I just want to clarify some of the speculation that we have been reading. You will realize at least 24-whp gains with no other supporting mods. With our 2.5” cat back and a K&N cold air we realized 31 whp increase with just the head. We speculate with out intake manifold and throttle body this number will raise even more. This is all done on a stock ecu; we have a couple scions here with E-manage and a AFC but these gains are realizes with on the stock ecu.
The gas mileage concern is way off. We have not specifically tested the gas mileage as all we do with the three TC’s that we own is build parts for them and ream on them. You should realize a gain in gas mileage not a decrease. All we are doing is making a bottle necked head more efficient; this is the same theory to an exhaust or an intake. If drive the exact same as you did before then you will not seem some big drop in gas mileage.
Now to the head package we do these in house they are flowed on our super flow; flow bench. 38% increase with stock valves is a huge increase. The drivability in these cars comes to life with this package. The throttle response is incredible and the car revs so much better. This is a great addition to any power adder that you decide to go with. Our turbo kit will be released in the beginning of March as we are almost out of the R&D stage. We will also be releasing a 2.5 cat back that is done now; a 3” turbo back that will bolt on with our kit, fuel rail kits, and sheet metal intake manifolds. Throttle bodies, etc..
All of our parts will be available exclusively through tctunerz.com for the time being. If you are interested in having us install these parts at our facility in Louisville, KY we will have special staged upgrades that will include free airfare for you to come get your car and drive it back.
-Kenny
tech@zeropointindustries.net for all of you tech questions
We will post dyno sheets and videos very soon.
jrv2000
02-21-2005, 06:08 PM
Hell yay...thats what we all want to see
ZPIracing
02-21-2005, 06:09 PM
how am i going to blow my engine im not going with some cheap kit im going either with a zex wet kit or a nx wet kit both will only let you spray when its at WOT and they also monitor the air fule ratio to keep it from being to rich. this is alot like adding forced induction with larger injectors becouse the nitrous is just providing o2 and the wet part in the name means it adds fule to the mix of nitrous so that it keeps the leavels of fuel to air safe if installe properly and used properly this should be just as safe as a turbo or a sc. the peaple are the ones that spray when there in 5th gear going 30 or the ones that buy cheap dry kits that dont monitor any thing and let you spray when ever you want
We have sprayed our Scion on a 120 shot for months and the only negative effect we have had is a blown intake manifold. This is why we now are building a sheetmetal one. We are trying to push the limits of these cars so that we can helo you guys with what the weak spots are. The tc block is proved to be very stout thus far and we will only tell with time when it will break
-kenny
aarontrini85
02-21-2005, 06:14 PM
^cool im not planing on doing a 120 shot im only looking to do a 55 maybe at most a 75 nothing that large
ZPIracing
02-21-2005, 07:25 PM
We have put 75 shot on three cars and they have all been fine; we only use nitrous express and we did put a pump in the cars they are all on stock plugs.
-kenny
ZPIracing
02-21-2005, 07:27 PM
there is a video of our car on tctunerz.com on a 120 shot racing a stage 1 srt-4 with upgraded fmic, 3" dump, boost controller running on high octane mode.
At the end of the video we let off of it coming up on some curves we walked the srt-4 pretty good.
-kenny
aarontrini85
02-21-2005, 07:29 PM
^ cool i will check that out and maybe ill go with a 120 shot once your new intake manifold is avalible
didnt seem that bad but it seems like you guys slowed down alot or his turbo spooled up and thats when he jumped infront. have you taken this car to the track yet? if so what did it run?
ZPIracing
02-21-2005, 11:41 PM
no ur tracks here don't open until next month. The scion woudl just take off when floored the other guy was honking so he should have had the reaction advantage. The srt-4 is a customer of ours it is a stock turbo so it spools quickly. The bottle was running a little low at this point it is just a good example of what TC is capable of.
The 120 shot was always done on race gas!!!!!!I would not suggest doing it; unless you have at least 100 octane and a step colder plugs
aarontrini85
02-21-2005, 11:54 PM
i was going to get the zex pluggs and i was planing on going using 93 octane but if the tc can take 100 with just the pluggs ill try it when i go to the track on april 2nd i cant wait to get the nitrous in and run it it will be fun
Joey_WRX
02-24-2005, 06:40 PM
do not use zex plugs, they are junk.
ZPIracing
02-24-2005, 08:29 PM
This is how we are going to do the heads if you have more money than time. If you want us to send you a Stage 1 head there will be a 725 core charge. I know this is expensive but this is the cheapest that we can buy these heads. They will be complete and assembled minus cams. All you woudl have to do is install your cams this not being that hard of a task that ost shade tree mechanics and tuners can do.
We still are having computer problems here at the shop so we can not post the dyno sheets. As soon as our scanner is working again we will post them we stand behind these claims 100% as we have seen and driven a few of these cars with this package and are thrilled with the results.
Thanks
-Kenny
Oh and Joey is right ZEX plugs are junk use NGK
aarontrini85
02-24-2005, 09:06 PM
what kind of plugs do you suggest i get then?
bambams247
02-24-2005, 09:21 PM
aarontrini85
02-24-2005, 10:17 PM
where do you order them from?
Joey_WRX
02-25-2005, 01:39 AM
if youre going to be spraying nitrous, stay away from platinum plugs, stick with copper, 2 steps colder.
aarontrini85
02-25-2005, 01:54 AM
so what do you suggest i go with?
sl0wp0ke
02-25-2005, 03:05 PM
-kenny
Dude I seriously hope you were joking.............I saw that video and if my prizm with a 100shot can beat a stg1 srt-4 with e/i then something is wrong. Im not trying to bash at all I just can't believe a 120 shot did that poorly against the modded srt-4. I knw those cars are fast seeing how there are 15 local ones that I all knw.
I could see you spraying a 55 shot in the video and loosing, but 120.
Mr_Meaty
02-25-2005, 06:25 PM
So, would you send us the new head, so that we can have it installed, and send you back the old head, or are you expecint us to send you our old head first, having you polish it, and then send it back?
( :lol: polish my head :P had to say it!)
KYBoy
02-25-2005, 06:43 PM
they send you a new one, and you send them the old one
jrv2000
02-25-2005, 10:17 PM
Is it more expensive if we want to keep our stock head?
aarontrini85
02-27-2005, 04:47 PM
^ the core charge is what you should get refunded once you send your old one in if you keep your old one you dont get it back
jrv2000
02-28-2005, 09:57 PM
how much is the core charge
aarontrini85
02-28-2005, 10:16 PM
he said $700 i think
