Tial Wastegate not opening
Old Apr 14, 2010 | 09:45 PM
Dkfung88's Avatar
Default Tial Wastegate not opening
So i bought a new tial wastegate 38mm (one of the older bigger silver ones) and i hooked up the vacuum line to the side of the wastegate. I was on half throttle and noticed my boost going up to 14-16psi. I have a .5 bar spring and i opened up my wastegate and made sure it is a .5 bar. im wondering if it would work if i hook up the vacuum line to the top of the wastegate instead of the side because the first tial wastegate i bought, i believe the vacuum was attached to the top and i thought it was broken because it was opening up so i bought this new one, and now that the vacuum is on the side, its not opening up at all. any ideas?
Old Apr 14, 2010 | 09:48 PM
m6ar2cel6oTC's Avatar
The top is for a boost controller.
Old Apr 14, 2010 | 09:53 PM
Dkfung88's Avatar
what is the side for? i heard the top is for a electronics boost controller while the other one is for a mbc
Old Apr 14, 2010 | 10:28 PM
cburglb34's Avatar
for electronic boost controllers u use both top n side..
Old Apr 14, 2010 | 10:52 PM
Dkfung88's Avatar
if not then i just stick with using the top part?
Old Apr 14, 2010 | 10:58 PM
cburglb34's Avatar
NO unless u have a EBC u need to use side and only side!!!!!
Old Apr 14, 2010 | 11:13 PM
Dkfung88's Avatar
hmmmmm...... my vacuum line is on the side... but its still boosting over 14lbs....
Old Apr 14, 2010 | 11:46 PM
crush02342002's Avatar
then you have a pinched, hole, loose vac line....or the diaphragm is damaged.
Old Apr 14, 2010 | 11:48 PM
cburglb34's Avatar
open wastgate remove spring...and pull up on the top hot that the diaphram is attached to...it should easily lift up along with the shaft of the valve...
oh and theres 4 set screws that hold that on the valve makes sure they are there n tight
Old Apr 15, 2010 | 12:06 AM
Dkfung88's Avatar
well i just took the wastegate off, and for a .5 bar spring, that piston on the bottom is pretty tight to push.... it took two thumbs and a lot of pressure before that piston moved... i think ill open it up when i get home
Old Apr 15, 2010 | 12:19 AM
cburglb34's Avatar
even a 5psi spring takes some pressure..... its not exhuast flow that overcomes the spring pressure its boost.....boost pushes the diapram and collapses the spring
Old Apr 15, 2010 | 12:29 AM
Dkfung88's Avatar
ill go home and take apart my wg and see whats wrong
Old Apr 15, 2010 | 01:25 AM
what vac source were you using for your wastegate?
SloTC1
Aug 16, 2018 02:45 PM
airmankevin1
Nov 17, 2015 05:44 AM
SoccerBoy_AP
Oct 1, 2015 06:28 AM
crimson_sinn
Sep 25, 2015 09:41 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
