how to run two things out of a 12v
Old Apr 23, 2010 | 04:25 PM
mrfuzzy4's Avatar
From: 'Burbs Farmington Hills - go to school in Boulder, CO
Default how to run two things out of a 12v
I'm trying to figure out how to hook up both my "new"(bought used) garmin nav system and my cousin's present to me - a lightly used cop scanner.
-required statement-
I KNOW MOST PEOPLE THINK COP SCANNERS ARE DUMB
-/required statement-
ok now that that's out of the way how would i go about plugging both into the 12v? i can't imagine a splitter working all that well, i just feel that if it could hold all that power pull they'd have made 2. anyways, what's the best way to go about it?
Thanks,
The G-
Old Apr 23, 2010 | 04:27 PM
CarbonXe's Avatar
Splitters work perfectly fine.
Old Apr 23, 2010 | 05:13 PM
egobuster1's Avatar
splitters are fine
Old Apr 23, 2010 | 06:41 PM
cavalierkid888's Avatar
Splitter work fine, though IMO they are kind of tacky. You can always splice them in and hardwire the devices to a 12v accessory source.
Old Apr 23, 2010 | 07:07 PM
mrfuzzy4's Avatar
I agree on the tacky splitters. I was thinking of trying to figure out a way to hardwire my garmin into the car. now what/where is a 12v accessory source that isn't the car outlet?
also, does the fact that i have the Randode cold cathode kit installed effect a splitter if i go that option?
Old Apr 23, 2010 | 08:04 PM
spr0k3t's Avatar
You could tap a fuse point by using the add-a-circuit. Very simple to install. Figure out which accessory point you want to use, whether the power is full time, switched accessory, or switched running and connect your power off that. Then use a splitter box and hardwire the splitter to the new fuse point. Mount the splitter box somewhere completely out of site under the dash. Then you have the accessory 12v jack completely unused and available for when you want it.
At least, that is how I would do it. Then you don't have to mess with trying to hardwire all the other components such as the garmin, the scanner, and possibly a raydar detector without having to mangle the power cables.
Old Apr 23, 2010 | 08:09 PM
EDDIEA123's Avatar
I used the power source from my cig. lighter....
Old Apr 24, 2010 | 07:16 AM
RedneckwithanxB's Avatar
12 gauge wire from battery to glove box
$7 6 fuse box from napa in glove box
12 gauge wire from fuse box to whatever you want
safe, easy, cheap
Old Apr 24, 2010 | 11:31 PM
Davestoaster's Avatar
Just so I know what I am thinking is right.
But what is a "cop scanner"?
And the splitters do work. I have one.
Just don't pull more amps than the fuse is rated
Or else............. POP !
Old Apr 26, 2010 | 03:47 PM
mrfuzzy4's Avatar
a cop scanner is the same as a radar scanner as a radar detector, it's just a little black box that tells you when a radar gun is nearby. it's not really THAT helpful, considering how most cops will flash you with radar (owned) or laser you (MAD owned), but it's a fun little piece.
Old Apr 26, 2010 | 04:05 PM
mrfuzzy4's Avatar
safe, easy, cheap
what about a ground? and what does the fuse box look like? this isn't a bad idea, just not sure how it works.
Old Apr 27, 2010 | 12:41 AM
You can ground on any piece of metal, the fuse box is under your dash on the drivers side.
I personally tapped into 12v for both my scanner and gps through the sunroof motor. The source is only powered with the car turned to accessory as well so they both turn on/off with the car.
There's a thread on here somewhere on how to do that if you decide to go that route.
Old Apr 27, 2010 | 03:17 AM
http://images.google.com/imgres?imgu...OoH_8Ab67tCvBQ
Old Apr 27, 2010 | 03:22 AM
Frizz's Avatar
Team ScionTific
There is no such thing as a cop scanner...
Old Apr 27, 2010 | 06:05 AM
Zman's Avatar
Yes huhhhhh, Doughnut detector.
That extra fuse box looks pretty sweet.
The add a fuse things are fine for LEDs and such I'm guessing, but higher power draws, (GPS, etc) may be different.
My Garmin's battery holds a charge for more than 4 hours I think anyway.
Old Apr 27, 2010 | 06:41 AM
mrfuzzy4's Avatar
sunroof motor?
for the fuse box, wouldn't i have to hook up resistors and such? how do i figure out how to run either 12v to everything?
cop scanner = radar detector.
like a cobra.
Old Apr 27, 2010 | 07:51 AM
spr0k3t's Avatar
First time I've ever heard a radar detector called a cop scanner.
Police Scanner
Radar Detector
I couldn't find anything related to either one using the term "cop scanner"... not even on urbandictionary or uncyclopedia... and my searchFu().is(beefStrong());
Old Apr 28, 2010 | 06:01 AM
Originally Posted by mrfuzzy4
sunroof motor?
like a cobra.
Sorry I just saw your in an xB, just go with what everybody else is saying though...
Old Apr 28, 2010 | 08:50 PM
Zman's Avatar
I would buy the add-a-fuse things if it is just for a radar detector and GPS.
Old Apr 28, 2010 | 09:46 PM
mrfuzzy4's Avatar
not sure sure exactly how to go about doing this though, which is the problem. So far i've gotten run a 12g cable from battery to new fuze box, and then 12g to whatever i want, and just ground the box to the body. but do i need to do anything else or do i just splice the power cable to the nav system and *whatever you call it* scanner.
