HELP HELP HELP car wont start
Car wont start everything turns on but needles and milage guages display and car wont crank on. HELP ASAP I NEED TO GO TO WORK TOMORROW MORNING thank you.
alrite wut happen was i think i blown one of my main fuse, i conneted a led wire to the ignition fuse under the sterring wheel, and my power wire to the led touch my ground wire and spark.....now my car wont start everything else work but the needle gauge and mileage
so your not cranking either ? just dead ? check the batter connections? is your key ____ed up ? if the sensor is not properly installed inside the key it wont start the car. check all the connections in the engine bay.
you shorted something out. the only thing that would happen is the fuses blowing.
did you check all the larger fuses?
fuses are suppose to blow so that you dont get continueous power to burn out the electronically components or melt the wires.
so it has to be the fuses.
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
