HID problem...Help
Old May 9, 2010 | 11:48 AM
Rydrdg's Avatar
Default HID problem...Help
Hey I installed HID kit a few weeks later the right side went out I check everything and it look fine but when I grab the HID voltage box and when it touch metal it sparks....any idea? is voltage box damage thats why it dont work?
Old May 9, 2010 | 12:47 PM
SR0529's Avatar
voltage box? are you mean "ballast"? ballast can damage if water get into it. try to take the ballast apart and blow dry it. see if that work.
try to check if the ballast or the light bulb doesn't work.
put the left side ballast to the right side see if it work. if it still doesn't work then check the fuse box. you might have to replace the fuse
Old May 9, 2010 | 02:24 PM
Olesen_Custom_Automotive's Avatar
Scion Dynasty
if you bought a cheap kit from ebay, then its just a poorly made ballast.
Old May 9, 2010 | 02:44 PM
SR0529's Avatar
i brought it from ebay and it works fine as long as there no water get into the ballast.
Old May 9, 2010 | 05:37 PM
Rydrdg's Avatar
Yah I got from ebay and the left side work but the right side balast box keep sparking when contact with metal....
Old May 19, 2010 | 04:22 PM
oxxomxxo's Avatar
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
get these....these are nice
Old May 19, 2010 | 04:32 PM
LunchBoXB's Avatar
+1 for DDM Tuning. Sooner or later, I think EVERYONE will be going here to get them.
Old Jun 7, 2010 | 08:33 PM
ScionCrisp's Avatar
Originally Posted by Rydrdg
Hey I installed HID kits a few weeks later the right side went out I check everything and it look fine but when I grab the HID voltage box and when it touch metal it sparks....any idea? is voltage box damage thats why it dont work?
Might be because it's wet or that it needs a relay.
Old Jun 7, 2010 | 11:15 PM
Vask's Avatar
ground is shorted to high voltage output. Touching it, your getting about 1500v (low amperage so its relatively not harmfull). I would wrap the entire thing in electrical tape to avoid sparking... but its going to die sooner or later.
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
hondajt
Dec 14, 2015 12:54 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Renuco612
Sep 16, 2015 09:01 AM
