Torque Damper
Old May 13, 2010 | 12:34 PM
Mach-box's Avatar
Default Torque Damper
I was wondering if anyone has used one for the xB. I am looking to get one. My motor rocks quite a bit. Also will one that was made for a tC work on an xB?
Old May 13, 2010 | 01:34 PM
coryjames's Avatar
you need the xb one they are diff we have a different passenger side motor mount. this will make it sound like there is a midget in your bay rubbing a file on your strut tower its far to noisy i would go with the motor mount. i mean look at this hot ness
Old May 13, 2010 | 01:43 PM
Mach-box's Avatar
how much of a _____ is it to replace?
Old May 13, 2010 | 01:47 PM
streetxdreamer's Avatar
I dont think the TC one will fit as it mounts to the strut tower on the XB.
Just FYI be prepared for more chassis vibration with either the damper or the urethane engine mount
Old May 13, 2010 | 02:26 PM
Mach-box's Avatar
yea I figured. I think now there is too much movement in the motor.
Old May 13, 2010 | 04:24 PM
elwaylite's Avatar
Too much movement because of a certain mod, or just too much movement from the factory? Guess I'm asking for a why?
TIA
Old May 13, 2010 | 04:58 PM
Mach-box's Avatar
I think all the torque from the turbo. I would guess. The new clutch probably doesn't help either.
Old May 13, 2010 | 05:05 PM
elwaylite's Avatar
Ah, so its not a concern for a NA vehicle?
Old May 13, 2010 | 05:48 PM
Mach-box's Avatar
I don't think so. But I can't say for sure.
Old May 14, 2010 | 06:22 AM
ScionFred's Avatar
Very easy unless your turbo setup is in the way like mine is. All I had to do was remove the intake piping from the turbo. Changing the MM took me about an hour if I count setup and clean up.
I'd get the GGP mount instead of the damper. If it's too stiff, Nurspec will soon be offering a softer 70A bushing for it.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
BlingSlade
Oct 19, 2016 12:39 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
JonathonK
Sep 22, 2015 07:27 PM
carid
Aug 31, 2015 11:17 AM
