View Full Version : Parking light wiring question
elwaylite
05-19-2010, 04:43 PM
Need to wire the Halo's tomorrow. Here is a pic of each side of the parking/flashers and I was wondering which ones are pos and neg for the parking lights, so the Halo's will work correctly. Thanks.
http://i261.photobucket.com/albums/ii47/jlwhid/IMG_2170.jpg
http://i261.photobucket.com/albums/ii47/jlwhid/IMG_2171.jpg
AcidDrop
05-19-2010, 07:23 PM
i've done 1 before but don't remember which wire was pos/neg but i think the white and green wires are the ones you are looking for, if you have a test light that would really help you. pm GOZO1 on here and ask him which wires go where because i installed his halos, btw which headlights did you end up getting?
elwaylite
05-19-2010, 07:29 PM
Yeah, thats what I was thinking since they were consistent between the two. I figured green as Neg and the white ones with black stripe as the Pos. I guess the third colored wire is for the flash.
AcidDrop
05-19-2010, 07:37 PM
yeah just hit up gozo1 so he can take a quick look under his hood because it was a while ago but he got the anzo dual halo headlights and the blinker socket it came with kept blowing the fuses so we had to use the oem blinker socket.
elwaylite
05-19-2010, 08:36 PM
Found this on the web, I'd guess the white with black is Neg and the Green is Pos. Funny colored ones are flashers.
PARKING LIGHTS ( - ) WHITE (-) (REQUIRES #R30-H RELAY) AT HEADLIGHT SWITCH PARKING LIGHTS ( + ) GREEN (+) 30 PIN PLUG TOP LEFT OF FUSEBOX
elwaylite
05-19-2010, 08:48 PM
DOH. I just figured I was goin about this all wrong. I completely forgot about the side reflector bulb on each headlight. It ONLY comes on with the p-light switch, and thats the one to use.
dumb*** :gun:
Gonna buy some clamp splicers and install in the AM. Hopefully these do not have the p-light fuse blow issue like the Anzos did, but maybe I oughta reuse the OEm just to be safe.
