View Full Version : Maintenece Light after oil change
sciondrgn
02-22-2005, 09:05 PM
My Light came on just before I had the oil changed but its still on.. I did a search and tried the reset method that was in the book as well as here posted in the forum but nothing seems to work..
In my book it says to turn the key to the OFF position and hold the trip button down adn turn the key to ON hold for 5 seconds and reset..
It also says the off position the odo will be on..
All I have is ACC ON START
Given that the ACC is off and on is on then it should work but my odo does not come on when clicked over to ACC just the cd player comes on. My odo will come on when the keys is "on"
Any help would be appreciated
sciondrgn
02-22-2005, 09:06 PM
I have an early 2005 xb - auto by teh way
nds_CARnivore
02-22-2005, 09:12 PM
Push in the ODO button. while holding in turn key to "ON", continue to hold ODO button in for 5 secs... done. I've got three oil changes in and just ignored the light unitl it drove me crazeee. I followed the manual and all is fine. I reset every 3thou when i change oil so that it won't bug me. Hope this helps.
stick_1NZ
02-22-2005, 09:14 PM
First off, did you get the dealership do the oil change? If yes, you might want to go back and have them reset the light. Hope this helps.
sciondrgn
02-22-2005, 09:15 PM
Thats what I tried and no go for me..
I tried two different ways
Put the key to ACC -> Push and hold button -> Flip key to ON and wait.
Also help the Button in and then put the key in and flipped to on and wait..
Nothing :\
sciondrgn
02-22-2005, 09:16 PM
No the dealers around here are whack I use an Oil change place that I have used for many years. This its Second Oil change. I gave up the free ones because of the dealer
snuppy
02-22-2005, 09:38 PM
http://www.scionlife.com/forums/viewtopic.php?t=20749
sounds like we're confusing ACC with OFF... OFF is completely OFF, such as before you even insert the key in the ignition...
sciondrgn
02-22-2005, 09:47 PM
Thats what i was thinking but i tried that as mentioned above.. i tried it both ways :\
I will try again when i get off from work and hopefully it will work..
thanks for everyones help
MrSparkle
02-22-2005, 09:49 PM
First you have to push in the button with it on and then turn it off while having the button pushed in still. Turn it back on and then you will see some lines that go away the longer you keep it pushed in. Once the lines are gone the light will be off. At no time release the button until the lines are gone.
sciondrgn
02-22-2005, 10:20 PM
I will try that Mr Sparkle thanks
sciondrgn
02-22-2005, 10:24 PM
Now that im looking at scion's faq it is misleading if your suppose to push the button while the odo is on
"1. Turn on the ignition and make sure it is on your odometer display, not the trip display.
2. Turn off your ignition. Hold down the trip meter reset button and turn the ignition on. Keep the button pushed in.
3. The maintenance required light will flash for a few seconds. when it turns off, let go of the reset button.
Number 2 says to turn the ignition off and push the button
sciondrgn
02-23-2005, 12:12 AM
I tried Mr Sparkles way and it worked thanks for all yals help
