audio tech assistance
Old May 31, 2010 | 08:43 AM
namesrooster's Avatar
Default audio tech assistance
hi..
i have some general questions about amp and subwoofers..
for instance.. if i was to run a 10w6v2 jl audio 10" subwoofer..600 watt rms-1200 max would i buy a amp that is 600 watt or 1200 watt..? should i buy something that matches the rms or the max wattage? what happens if i go over the rms or max or under?
thanks!
Old May 31, 2010 | 11:22 AM
STlTCHES's Avatar
Alot of audio stores pitch the max watts to people that don't know anything about subs/amps. Max watts is what the amp/sub can only be handled for brief time periods before potentially damaging it. RMS is the true value of the sub/amp this is what the amp plays at without much risk. (that's assuming a perfect install)
I'd recommend getting an amp that runs a little over the RMS like 800w.
That's so you can crank it without worry of running over the 1200w max rating. You also don't want to push a sub with too little power. Doing that can damage the sub.
Old May 31, 2010 | 02:15 PM
Olesen_Custom_Automotive's Avatar
Scion Dynasty
get an amp that is 2006 CEA compliant.
it means it was tested to be sure the wattage is true, peak and rms.
get a mono class D JL audio amp, all of them are CEA compliant
Old May 31, 2010 | 06:20 PM
Makaveli's Avatar
Originally Posted by namesrooster
hi..
thanks!
http://mobile.jlaudio.com/products_s...php?page_id=35
This should explain everything
tc-guy's Avatar
i would run the jl 500/1 slash amp. it would be ideal for your sub.
Old Jun 1, 2010 | 07:56 PM
blazeplacid's Avatar
rms is what you are looking for
RMS = root mean square or average
Think about RMS and Max this way. Say you can bench 100lbs all day everyday.
Now lets say your max is 250lbs and you are really stressing to put up the weight, you can, but not as long and you start to over heat.
Same with a sub or amp. They can do close to max for short periods of time.
Please remember RMS is just a numbers game, wattage fluctuates with frequency as well as volume level
id give the sub 600-800rms
Old Jun 2, 2010 | 07:18 AM
so what im getting at from all of these replies are. if for ex. i have a 500 rms watt sub 1000 max get something thats a little more around 600-800 watt amp..
or 300 watt rms and 600 max. get around 400-500 watt amp?
same goes for speakers?
Old Jun 2, 2010 | 02:11 PM
dont go by max
some companies greatly exaggerate the max to make em seem like high wattage amps
yes, find an amp around 500-800 rms. Try to stick with a known quailty brand
What is your budget?
Old Jun 2, 2010 | 05:07 PM
Makaveli's Avatar
Read the link I posted earlier. 600-800 watts like blazeplacid recommends would void the warranty. 500 watts is ideal...600 is the maximum RMS it can handle.
The enclosure type also makes a difference in power handling. Sealed will handle the most power. Ported will handle less. Infinite baffle will handle the least.
Old Jun 2, 2010 | 05:28 PM
GQQSE13's Avatar
Originally Posted by blazeplacid
dont go by max
x2! i love when i see people with garbage amps from wal mart that claim like 800 watts but when you look and the rms is like 200-300 lol
Old Jun 2, 2010 | 05:33 PM
Scion Dynasty
sony xplodes claim 1200max but rms at 150w
Old Jun 8, 2010 | 02:25 PM
ive always fed my subs more than recommended and have had great success
Im running a RE Se 10" with 900rms, the sub is rated at 600rms. been going strong for 5 months
Old Jun 8, 2010 | 11:33 PM
Makaveli's Avatar
Power ratings are a guideline...you can do what you wish but you best believe the manufacturer won't help if you send back a fried coil.
Old Jun 9, 2010 | 12:40 AM
09SocalTC's Avatar
600 is not the max it can handle...most subwoofers are underrated, because companies know people will push them hard! i bet it could handle 750rms if you know what your doing, and have a good unclipped signal.
Old Jun 9, 2010 | 01:59 AM
Makaveli's Avatar
Like I said earlier...you can give it more but it would void the warranty.
Old Jun 9, 2010 | 03:00 AM
Murphys_Law's Avatar
800 rms will butcher that sub, get a jl 500/1(half slasher) or a kicker zx300.1, theyre good amps ive had a few
Old Jun 9, 2010 | 03:02 AM
more like 100-150rms out of that crap (lightning audio,pyle,boss,phoenix digital,low end sony,audiopipe,new hifonics)
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
