So, starting today, my xD doesn't beep or flash when I lock it. It beeps twice and flashed like normal, when I in lock it. It does lock when I press the lock button, just no beep and no flash of the lights.
I tried opening and closing each door and the hatch just to be sure. That didn't help.
Any ideas?
Murphys_Law
06-01-2010, 03:25 AM
in valet mode? my viper on my truck can be set to silent, is it an oem keyless/alarm
mcbrew
06-01-2010, 03:43 AM
Sorry, let me add more details. Everything is stock. No alarm system. OEM key. I tried both key remotes and the same thing happens. Everything appears completely normal, except it does not flash/beep when it locks. It does double flas/double beep when unlocking. It just stopped doing it when locking. I can't find anything else out of p,ace, but i want to fix it. Something is wrong... It had beeped and flashed every time I lock it for the last year and a half. Now it has changed all of a sudden.
For what it is worth, it will still do the long beeeeeeeeeeep if I try to lock it when a door is open.
Murphys_Law
06-01-2010, 04:36 AM
i dunno maybe the keyless entry still has a silent mode
mcbrew
06-01-2010, 04:41 AM
Well, it isn't all that silent, being that it still beeps and flashes when I unlock it. Something is up... Maybe I'll call Scion tomorrow if I can find some free time at work.
JJGeneral1
06-01-2010, 12:46 PM
my old xD did that for a bit. then it eventually worked again. not sure what caused it.
mcbrew
06-01-2010, 02:27 PM
Funny you should mention that.
My car was still not beeping/flashing this morning. After getting to work, I had to go out and get stuff from my car three times. The third time, when I locked it, there was a bried pause, then it beeped and flashed! I unlocked it and locked it again, and it beeped and flashed like normal. I didn't do anything to the car. I opened a door and got something out... but that door has been opened and closed at least ten times in the last 24 hours, so I don't think that had anything to do with it.
Odd.... I'd still like to know what the heck was going on.
Jan06xB
06-01-2010, 02:33 PM
check the dome light operation with the door buttons that turn on the light - that controls the door lock system since it monitors to see if the doors are open or closed by those push button switches.
mcbrew
06-02-2010, 02:16 AM
I was thinking along the same lines... But with the xD, if a door is open and you hit the lock button, you get a loooooooong annoying beep. I didn't get that, except for when I opened a door and tried it on purpose.
I have to chalk this up to "it fixed itself".
JDMJim
06-02-2010, 07:01 PM
mine does this occasionally. no visual/audible notice the car is locked other than hearing it lock. open and close the door thinking I didn't close the door. It worked again and has been fine since. Domelight has nothing to do with this issue. But i mentioned somewhere else the car a weird aura about it right now.
GuitarJoe03
06-06-2010, 05:12 AM
Mine does the same thing occasionally too - usually when this happens, the front passenger door gets "jammed" and won't open from the outside even when all other doors are unlocked and will open. After I open the door from inside the car and close it, it will beep/flash and go back to normal.
I've always blamed it on my wife, but last weekend the same thing happened to the rear driver's side door. :ponder:
mcbrew
06-06-2010, 05:36 PM
Strange! I would certainly take it in and have them look at it. I was annoyed enough that mine didn't beep. If doors weren't opening, it would be in for warranty work.
