MAJOR DOWNSIDE of cold air intakes?
Old Feb 25, 2005 | 12:33 AM
miraclecreator's Avatar
Default MAJOR DOWNSIDE of cold air intakes?
Ihave a question, I heard that there's a MAJOR DOWNSIDE on the cold air induction systems. Since it's a COLD AIR intake and not a regular intake, it'll be longer so it can be extended to the near bottom of the car and get the colder air thus giving it more HP. BUT! The major downside is that if you come across a puddle or something like that, there's a good chance that the water will get sucked into the engine from the intake since it's so close to the floor and ultimately destroying the engine. So i was told that the only way to prevent this is to put it in Neutral and turn off ur engine, and turn it back on when u have passed the puddle. Can anyone tell me how true this is?
Old Feb 25, 2005 | 12:43 AM
sexyscionlover's Avatar
haha. im gonna say noooooooo on this one. i think you might do more damage doing that, rather than just driving over it. cases i've seen, is where they've parked in a puddle where its submerged. driving over a puddle will not shut your engine down. it would also have to be water covering the whole filter, otherwise it would just get a little air. if your really worried, install a bypass valve i suppose. i dont think you need to worry though
Old Feb 25, 2005 | 12:50 AM
S2nrXa217's Avatar
dude you should be fine what do you think the splash gaurd is
for and you would have to go in a pretty deep puddel.
jmiller20874's Avatar
There are 2 downsides to CAI
1) You sacrifice a little low end torque.
2) Hydrolocking (water entrering engine) - Some intakes come with a water bypass valve to direct water out, but even it it doesn't, it'll take more than simply running through a puddle to cause hydrolock.
A mere puddle will not cause water to go into the intake basically because when your front tire hits the puddle, your CAI is already past it. You'd have to hit a mighty deep puddle to force water up there, in which case I'd worry about hydroplaning. Putting the car in Neutral would do nothing, the engine is still running therefore still sucking air. So to be safe, get one with a bypass valve and you'll be fine.
Old Feb 25, 2005 | 01:34 AM
then i have another question. u guys know all those hoods with scopes or "holes" or w/e. Didnt they think of what will happen if it's raining and the water goes into the engine area as well as the intake?? I'm just wondering. Pls do correct me if I'm wrong.
Old Feb 25, 2005 | 01:44 AM
TimmyT's Avatar
Scion Society
Scoops are great for cars with carbs or top mounted intercoolers. Vented hoods help hot air escape from the engine bay. In japan and surrounding areas. Hood spacers are really hot right now. If you have a short ram intake such as the secret weapon. I'd recommend either the vented hood, or save yourself 700 bucks and just buy hood spacers But vented hoods and hood scoops while driving shouldn't let much water into the engine bay or around your intake. Parked in the rain. Your engine is most likely not running anyway. If you are worried about water getting near your intake. Then once again I'd recommend hood spacers instead of a vented hood.
Old Feb 25, 2005 | 01:46 AM
pls dont laugh when I ask, what is a hood spacers again? (?_?)
Old Feb 25, 2005 | 01:49 AM
TimmyT's Avatar
Scion Society
Hood spacers are just lil rubber spacers for your hood. Its not very cosmetic. It lifts the hood a little bit where the hinges are and lets hot air escape through the space.
Old Mar 1, 2005 | 04:14 AM
blitzcat's Avatar
A limited amount of water going into the engine is ok. Rally cars used to (may not be allowed now) put a fuel injector just before the intercooler spraying WATER into the air about to go into the engine. The reason for this is that water has such a high heat capacity that it would further cool the intake air temp enough that more air could be compressed into the cylinders. Meaning more available oxygen to burn, so more fuel could be used, so more peak horsepower.
So I wouldn't sweat a little puddle splashing or rainwater on the infuent air to your engine.
It becomes a problem when the volume of water in the cylinders steals enough 'air space' that the total air compression ration exceeds 11:1 for regular gasoline, detonation begins to occur. As the amount of water increases, air pressure increases exponentially on the cylinder walls and piston head. At the same time the rapid and uneven tempature drop of parts in contact with water can cause them to warp and distort.
Old Mar 1, 2005 | 04:30 AM
jlaznlover's Avatar
blah, i nevered put on a cai because of im afraid of hydrolocking my motor. a bypass valve is added security if you have a cai, but i am rather skeptic about it function 100% of the time. most people that i have spoken to, they have said the bypass valve only functions when the entire filter is submerged in water. hmmm, i no idea if there is some or any truth to their statements. i prefer a short ram anyways.
my buddies friend, mike, had a aem cai(with bypass valve) on his 95 accord. he accidently drove right into a deep puddle during one of those rainy florida days. hydrolocked his motor and stalled right in the puddle. made a nice big crack in the engine block as well. since then, he swapped a h22a in there. this was the incident that discouraged me from ever buying a cai.
KINGxOFxSKA's Avatar
Unique Scionikz
plus... the little water (if it did) get into the intake would probably get hot and steam away by the time it would ever enter yer engine.
Old Mar 1, 2005 | 05:06 AM
Water turns to steam at 212F, so you're telling me the air stream is hot enough to steam water. Plus even if it did turn to steam, where's it gonna go? It'll follow the air stream right into the intake manifold.
Old Mar 1, 2005 | 04:08 PM
aarontrini85's Avatar
the srt-4's also do this if you get there turbo toys upgrade for it
http://www.mopar.com/street/products_srt4_stage2.htm
http://www.mopar.com/street/products_srt4_stage3.htm
Old Mar 1, 2005 | 04:09 PM
RA31925's Avatar
to heaven
Old Mar 1, 2005 | 04:43 PM
Kremtok's Avatar
You know, I'm glad someone started this topic. I have been debating a warm versus cold air intake since I bought my car in August. Naturally, I want to let the engine breathe as effeciently as possible. My primary concern is that the air temperature where I live is too cold, and if I use a cold air intake, my engine will run at lower than normal operating temperature. That would mean, among other things, decreased interior heater performance. You all seem to be very knowledgeable; what do you recommend for my application?
Old Mar 1, 2005 | 04:54 PM
My gut is telling me you should be better off with a short ram. The air in the engine compartment would be warmer compared to pulling the air from the bottom of the bumper. Short ram would increase your air volume but can anyone say if there would be that big of a difference in temp between a CAI and a Short ram?
Lonely_Raven's Avatar
The Porsche 924 and 944 have an OPEN duct right into
the wheel well and has been that way since the late 70's.
Mine takes up water all the time, but the length of the piping
makes it near impossible for that mild air flow to suck in
any water.
I can't imagine a naturally asperated 1.5L having enough
suck to pull any noticable water through the filter. You'd
probably get a blocked up filter long before you'd get
hydrolock.
Old Mar 3, 2005 | 06:09 PM
Mr_Meaty's Avatar
The major downside to a CAI, or any after market intake for that matter is that you can't use it with a TURBO!
Plus, it's so damn hot here in Vegas, I dont' know how much of a difference it would make. The asphault gets so hot here.
Old Mar 3, 2005 | 07:40 PM
jwaggz82's Avatar
If you guys are that worried about your intakes --- you better already have new pipes because your gains will be cut in 1/2. Also - I think you are right - keep your stock filter and forget about the intake. In another month people will be talking more about the supercharger.
Old Apr 18, 2005 | 10:43 PM
tc05's Avatar
New pipes what do you mean enlighten me. I dont know what you mean by this
