Scion xD Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
sway bar and strut towers..
Old Jun 23, 2010 | 01:22 AM
Scion xDanno's Avatar
Default sway bar and strut towers..
ok, so I understand what the two are...
my question is, do I need them?
why or why not? i do have a heavy foot, so i figured ill need one or the other, prob the sway bar.
but while looking around, i noticed tanabe makes a front strut tower bar, so im asking do people make rear ones? do we need just the front? just the rear?or both?
Old Jun 23, 2010 | 06:20 AM
CK028's Avatar
first off, i am not highly educated on suspension components but i will share with you what i DO know.
sway bars link opposite ends of your suspension from underneath, therefore they are more useful than tower bars (i say this per things i have read on here). whereas tower bars do the same, but they are on top of the suspension meaning they provide less use. i know that the tc has a rear tower bar, maybe even the xb. as for the xd? no idea. google it, you might find one or two.
(EDIT: ^^ i don't know exactly how they work, i just have an idea as to what they do)
i would imagine getting front and rear sways as well as at least the front tower bar would tighten your ish up pretty well. it should eliminate most body roll and provide much better handling.
if you are lowered, sways are pretty much a must. the stock sways are not designed to support a lower center of gravity, therefore producing more body roll than normal.
if i am wrong, fill me in.
Old Jun 23, 2010 | 06:49 AM
sway bars, is there only one? or is there a rear and a front sway bar?
Old Jun 23, 2010 | 01:43 PM
mixD's Avatar
For the xD there is only a front strut tower and a rear sway bar a good combo for our cars is tanabe strut tower and trd sway bar on the rear if u lower the car and put a nice set of tires on this upgrade will give u the full feel. what these items do is when u go around a corner the body of your vehicle, tho not much, flex's and this causes the car to get sloppy in a corner. these two items delete that slop and force the car to stay stiff in the corner and will make the car turn sharp and flat when making a hard turn. its a good investment easy to install the front tower bar the sway bar can be a little harder but not to bad and its a cheap performance part that will make a big difference that u will notice.
Old Jun 23, 2010 | 01:51 PM
FlintMica2005's Avatar
front strut bar=waste unless you have coilovers.
the sway bar will definatly be a better piece of the 2, youll actually feel that unlike the strut bar
Old Jun 23, 2010 | 06:07 PM
Vlad1024's Avatar
During hard(and I mean HARD) cornering the body deforms a little and the wheels start to lean. The strut bar connects the top of the struts adding rigidity to the body eliminating this effect. However this is so small that you won't feel it unless you have a massively upgraded suspension and are hard core autoxing(and even then I have my doubts).
Sway bars are good. They connect the left and right suspensions and keep the car level in turns which makes it feel better. I have 2, one in front and one in the back, but you only have the one in front because you have a tortion beam rear suspension(WIKI!) as opposed to the tc's double wishbone. What they call a swaybar for the xD is really just a reinforcement for the beam but it works the same way. It is really easy to install, Just reach under the car and bolt it in place. Trdsparks has them(and instructions free to download)(along with many other toyota parts.
I suggest you read the stickys in all of the tC forums on this site. There is some good info for beginners. Also this.
Old Jun 23, 2010 | 06:39 PM
thanks everyone, this helps alot,
thanks to mixd for important info for my future shopping needs lol
special thanks to to vlad for showing those posts, major help
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
rvascion
Nov 12, 2020 03:23 AM
SloTC1
Aug 16, 2018 02:45 PM
kb1sxv
Oct 21, 2015 05:00 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
