o87PanterA03o
06-24-2010, 05:14 PM
sry if this has already been asked, i've read pretty much every led thread on here over the past couple months and my question seems a little more complex than anything i have seen...
first off i bought the OEM illumination lights which i must say i was VERY disappointed with... so using the same wiring i basically swapped out the led strips, and cupholder leds, while adding a few more ... it looks rly good but this is what i want to happen:
i want the lights to operate exactly like the dome lights, turn on when i unlock the car etc... this is a simple tap into the dome light power source. thats easy enough. but i also want them to stay on when the doors are shut unlike the dome lights. how would i do this?
one solution i came up with is to replace the OEM switch with a simple 2 way switch that would switch the power source from DOME to CIG. the only thing is i would like them to stay on when the doors are shut without me having to switch to CIG power...
so if it is possible to have it do all that together (turn on like dome lights, and then stay on after door is shut) then the 2nd switch option would be to just cut the power completely.
and just another question that might widen up solution possibilities. do they make 3 way switches for our cars that would fit in those slots? the button switch i have already has 4 settings (footwells light up only, cupholders only, both on, both off) but idk if that could be integrated into this new lighting arrangement... i rly only want all of them on or off at the same time so the current setting on that switch is kind of annoying
thanks for any ideas or comments
