View Full Version : A/C Compressor
Werewolf6410
06-25-2010, 06:04 PM
I have a 2007 Scion tC and the A/C compressor is going out on it, the stealership said with would be $2200 to repair :shock::question: and that just doesn't sound right, I know i can replace the compressor myself, i just don't know how to do the gas part of it. can i just bleed the gas off, replace the compressor then take it to a repair shop to have them refill it. i'm going to be replacing the dries, and flushing the condensor and maybe even adding an inline filter to help a little more. i can buy a brand new compressor for around 350$ and i refuse to pay someone $2200 for something i know i can do on my own. any ideas on how to recharge the system after i get the new compressor on?
badcooliebwoy
06-25-2010, 07:42 PM
I would drain it, then replace the compressor, then do a refill. Quick question..do you notice a rattling noise when you turn on the a/c? I have a feeling mine is going to I just wanna be sure.
thendawg
06-25-2010, 09:24 PM
Technically you can charge 134a yourself. You can buy a gauge/manifold set than buy cans of 134a from your local auto supply. One thing you will also need is a vacuum pump to pull a vacuum on the system and remove any contaminants. You will also need to add oil back into the system - which lubricates the compressor. I know you can rent the gauge/manifold set and vacuum pump from autozone around here, so Im sure you can anywhere.
squir3lz
06-26-2010, 06:48 AM
There is some on there from 400 to 30 dollars most are around 50 to 100 buy it drain it fill it 150 200 dollar fix
http://www.car-part.com/cgi-bin/search.cgi?userSearch=int&userPID=1000&userLocation=All+States&userIMS=&userInterchange=BF%3DB%3E&userSide=&userDate=2007&userDate2=2007&dbModel=98.1.1.1&userModel=Scion%20tc&dbPart=682.1&userPart=A/C%20Compressor&sessionID=200000000000000000196863363&userPreference=price&userZip=97535&userLat=42.2654&userLong=-122.8108&userUID=0&userBroker=&iKey=&userPage=24
emptystreets130
06-27-2010, 07:14 PM
This is a proper way of doing the job. If you do not have a air tight system, then you run the risk of having the ac system failing or not cooling properly.
TcPrincess
06-28-2010, 12:23 AM
if your sure its your compressor then you can have a shop evac. your system. then take it home, take the compressor out and flush the entire system (there is a tool and solvent for this). install the new compressor and take it back and have them recharge with oil and dye.
Murphys_Law
06-28-2010, 01:03 AM
the member RevolutionAutomotive has one for sale i believe on here. PM her
