five axis sideskirts warping
Old Jun 26, 2010 | 03:57 AM
The01Cav's Avatar
Default five axis sideskirts warping
so I am running into some sagging/warping on the bottom of my five axis sideskirts. Does anyone else have this issue and if so any solutions to fix the sagging?
Old Jun 26, 2010 | 03:59 AM
tC4italy's Avatar
did you jack up yr car at any point?
I have same thing on right side skirt and I'm pretty sure it's because of tryin to get a jack under there.
My rs1 lip kit never bent.
Old Jun 26, 2010 | 04:09 AM
The01Cav's Avatar
Nope they were a tad warped after paint but have sagged worse at the bottom.
Old Jun 26, 2010 | 04:14 AM
tC4italy's Avatar
kinda like in a V shape?
Old Jun 26, 2010 | 04:20 AM
The01Cav's Avatar
almost like a W actually. right around the door area but at the bottom. I think that there should be tabs there to hold them in place to support them, but there is nothing there to do so.
Old Jun 26, 2010 | 04:31 AM
tC4italy's Avatar
I'll check mine for you tomorrow, see if I have tabs
Old Jun 26, 2010 | 04:34 AM
scion_jon's Avatar
this makes me queezy
Old Jun 26, 2010 | 05:07 AM
Domo's Avatar
not sagging but I have waves from a retarded installation by MPH motorsports.
Old Jun 26, 2010 | 05:59 AM
Mos_Def's Avatar
mine is warped a bit too on the sides. i wouldnt worry about it too much.
Old Jun 26, 2010 | 07:03 AM
XIEmperorIX's Avatar
Well considering this is basically a $1k kit (or nearly so) I would be concerned. Have you thought of maybe contacting five axis and seeing what they have to say? It couldn't hurt.
Old Jun 26, 2010 | 03:00 PM
Domo's Avatar
I don't think its a problem. Take some pictures and show us the warping.
Old Jun 26, 2010 | 04:53 PM
Mos_Def's Avatar
to be honest, i think its the paint, not the sideskirt itself. when i looked at mine, it looks like the paint is the one giving the illusion of warping. when i run my hand thru it, i dont feel any abnormalities.
Old Jun 26, 2010 | 05:25 PM
ah i c..I would definitely be ____ed if I had a 5axis lip and it started warping and ____ hah
Old Jun 26, 2010 | 05:36 PM
silvrtc300's Avatar
No warparge here.. I have mounted brackets in the the center.. But is polly uerathane.. With heat, it tends to soften it up.. and the roads being hotter than ever and the kit sitting as low as it does. yeah.. most likely the cause..
Old Jun 26, 2010 | 05:38 PM
silvrtc300's Avatar
RS1 is normally either ABS or C/F.. it's more rigid than Poly. But poly bends so no cracking.. POLY FTW..
Old Jun 26, 2010 | 06:03 PM
jamessicat25's Avatar
PICS!
Old Jun 26, 2010 | 06:08 PM
The01Cav's Avatar
Passenger side is a lot worse. Both look alot worse in person as well. To be honest the rear lip is really wavy too.
Drivers
Passenger.
Old Jun 26, 2010 | 11:50 PM
Domo's Avatar
that looks fine to me
Old Jun 27, 2010 | 02:17 AM
The01Cav's Avatar
far from fine. especially the passenger side.
Old Jun 27, 2010 | 06:00 AM
looks like my grandma's
