Built motor roll call...
Old Jul 2, 2010 | 03:58 PM
brett561tc's Avatar
Default Built motor roll call...
when did it go in the car? is it still running? mod list?...
got mine in feb 2007, still running, golden eagle sleeved shortblock w/ cp 8.5:1 pistons, carrillo super a rods, acl bearings, and arp head studs.
Old Jul 2, 2010 | 05:20 PM
TCpete's Avatar
still going.. shockingly enough despite all the clutch and flywheel issues ive had
since 07 ....11.1 weisco pistons / oem rods / acl bearings / arp head studs.... waiting for it to pop eventually (i hope not though)
Old Jul 2, 2010 | 05:31 PM
thendawg's Avatar
Dropped mine in about 2 months ago in early May '10. Has 5000 miles on it haha - dont know how Ive managed that. JE 9:1 pistons, K1 rods, ACL mains/rod bearings and thrust, ARP Head studs, Cometic HG - all the rest is stock. Entire motor and the rest of the work was built in my garage lol - minus the machine work which was done at a great company here in OKC - Buddy Rice Precision Engine - to be honest some of the best guys Ive had the privileged of working with.
Ohh, guess I should mention - still runnin strong
Old Jul 2, 2010 | 06:22 PM
trd07tc's Avatar
CP Pistons 88.5/K1 Rods/ARP Head Studs/Cometic Gasket/ACL Bearings
put 30k on it.
2009-2010 winter I rebuilt with new rings, head gasket, bearings.
Have 800 on it
Old Jul 2, 2010 | 06:58 PM
a-mendoza's Avatar
currently building mine in my garage. Should be in the car and cranked over next month.
Dezod short block (ARP main studs, MID Darton sleeves, Wiseco 8.8:1 pistons, K1 rods, ACL race bearings), Stock head, ARP head studs, Cometic head gasket.
Old Jul 2, 2010 | 07:20 PM
RusWolf's Avatar
ERL built and sleeved block.
JE pistons 9.0:1, K1 rods, ACL bearings, ERL/Darton Sleeves, deleted balancers.
Dezod built head.
Rev valves, titanium retainer, BC stage 2 cams..pretty much everything what can be done in the head except PnP.
Installed fall 09.
only have 500 miles and 35+ miles of that was dyno and tuning... I'm deployed so i only got a chance to drive the car on leave back in jaruary.
Old Jul 2, 2010 | 07:35 PM
flintMicaTC's Avatar
mine's being put in this weekend... Wiseco 8.8:1 pistons, K1 rods, ACL race bearings, Stock head, ARP head studs, Cometic head gasket should mate up well with the turbotoyota's kit... only thing i have planned for the future is standalone and return system...
last time i ever saw them
Old Jul 2, 2010 | 07:50 PM
brett561tc's Avatar
congrats
Old Jul 2, 2010 | 08:18 PM
thendawg's Avatar
Anyone who wants to take the venture of building their own return fuel system to save some money - feel free to talk to me - Id be happy to give out my parts list. I built my complete return fuel system INCLUDING Walbro 255 for $310
Old Jul 2, 2010 | 09:20 PM
yamaha16bw's Avatar
Started mine up for the first time end of June 09. Been running good since...
Wiseco 9.0 89mm, manley rods, acl bearings, arp head and mains, cometic hg, bc na stage 2 cams, balance shafts out.
Old Jul 2, 2010 | 09:33 PM
TCpete's Avatar
hows the vibration with the balance shafts out??? ^^^ i have yet to go that route but im tempted to do it...
Old Jul 2, 2010 | 09:50 PM
silvrtc300's Avatar
OK..
1st - ERL Perfomance Built in like 08 JE Pistions, K1 Rods, Sleeved, Super Decked, Block Gaurd, ACL COATED bearing.. Carv2 PNP head with Dezod Head components minus the valve guides.. Running on the Ultimate with just 850cc and a 255 walboro pump. Went good till the timing sprocket on the crank snapped after a couple months after my first tune and grenaded the head.. 15lbs Stongest it's every ran..
2nd - Still the same ERL Block decided to Swayne Tech coat the new pistons bearings and what ever else.. Dezod Full PNP head. And still running on the Ultimate with 15 lbs Blew out 3rd gear completely no teeth.
3rd - Still the same ERL Block And Dezod Full PNP head. with arp mains this time. New - BC Cams, Descendant intake manifold, Fuel Return System, And on the Ems and a Quaife/TRD diff in the trans.. Street tuned for about 15lbs.. Ran strong but never got it to it's full pontential.. Snapped an Axle..
4th - *(Current) ERL Block still doing good and just ripped her down and she's ready to be put back together for some more.. But Got a Dezod Full Built Speced out engine with New Dezod PNP head with 1mm bigger Valves, New Cams, New intake mani cable controlled, going run Aem EMS full stand alone with a new fuel setup. AND bigger turbo and new turbo manifold full custom pipes and intercooler setup.. and water meth.. We'll see hopefully this year what she does...
5th - thinking about for the ERL block BC storker kit bored out to a 2.6.. we'll see..
I normally replace and go bigger as something breaks or is needed. But the built ERL Block has been through a stuff load and still amazes me on everytime i pulled her apart she look just as good as i put her together.. Minus the carbon build up inwhich is very minor.. .....
Old Jul 2, 2010 | 09:56 PM
silvrtc300's Avatar
Never had much vibrations at all.. And i had solid Polly mount front and rear. Only on engaging the stage 4 four puck sprung disc on a 12 lbs flywheel.. She road smoothly as a stock block.. Hit Chintastic up, he's been in person with the car since the beginning. Know's the inside and outside of the car as much as I do.
Old Jul 2, 2010 | 11:49 PM
yamaha16bw's Avatar
Barely feel it at all. I did that and the energy mounts at the same time so I think the mounts give me alittle.....I dont think its from the shafts.
Old Jul 3, 2010 | 12:51 AM
gingles's Avatar
jesus did noone else go with the callico bearings?
anyway....wiseco 90mm pistons, k1 rods, arp head studs, callico race bearings all over, balanced crank..
built at 90k miles....110k now and going strong. i built it...put 500 miles on it then drove around 1500 miles in one sitting when i moved.
Old Jul 3, 2010 | 02:55 AM
m6ar2cel6oTC's Avatar
Lol cranky walk! Lol cars down again my crank spit out the thrust bearing. I dropped the pan and guess what I saw!!!! Nice glitter sand lol. Guessing the bearings wear. And the nice thrust bearing was just laying in my oil pan. So now putting in acl race bearing instead of those clevite bearings. And soon to change my pressure plate.
By the way I have wiseco 9.0 pistons, k1 rods, clevite bearings, balance shaft delete. Rev valves, rev dual wound spring and retainers.
Was at over a year strong but then melted piston and now this! Might rebuild or just sell the car. Dunno yet.
Old Jul 3, 2010 | 03:00 AM
1989menace's Avatar
got my built motor a few months ago. too lazy to list all the parts but its a ptuning spec ss block. still running strong and perfect with no boost and still plan on building the head and adding boost...pics are up on my build thread.
Old Jul 3, 2010 | 03:20 AM
weezyfbayba's Avatar
JOTECH FULLY-BUILT SHORTBLOCK: Godzilla
Sleeves O-Ring And Final Bore & Hone Arias Pistons
(Coated) Pauter Connecting Rods ARP Head Studs
Complete Main & Rod Bearings Water Pump Oil Pump
Complete Gasket Set Prep & Clean Micro-Polish
Crankshaft & Balance Blueprint & Assembly
JOTECH DVM STAGE 3 CYLINDER HEAD:
STAGE 3 PORT & POLISH
COMPETITION VALVE JOB
SURFACE CYLINDER HEAD
CLEAN CYLINDER HEAD
REV VALVES: (16)STAINLESS STEEL VALVES,
TITANIUM RETAINERS, ffl-COMP SPRINGS,
LOCATORS, SEALS, VALVE GUIDES
Old Jul 3, 2010 | 03:30 AM
chintastictc's Avatar
yeh daves tc has been through alot of changes...haha....it ran smooth ...and pull EXTREMELY HARD....proof search "45-110" on youtube lol...
Old Jul 3, 2010 | 05:06 PM
TCpete's Avatar
thats probably because of the act clutch ZOMGdezod recommended you... its way to much for a tc... that sucks man... holla at me when u can!
